Author: Subject: Mini wiper electrics
MB
posted on 11/1/03 at 09:40 PM Reply With Quote
I've just got hold of a new mini wiper motor and it has 5 wires coming out of it. Does anyone one know what they are for or have a wiring diagram?
Ian Pearson
posted on 11/1/03 at 10:09 PM Reply With Quote
If you have a look on the RHOC website under builders tips, there's an article on the mini wiper motor. Not sure if it'll help?!
Regards, Ian.
http://www.rhocar.org.uk/buildtipz/001.shtml
bob
posted on 11/1/03 at 11:13 PM Reply With Quote
How much did you pay for the new wiper motor ? and where from ?
cheers
jollygreengiant
posted on 11/1/03 at 11:45 PM Reply With Quote
use a multi meter to identify what circuit each wire runs. They should be:
1 - common/earth might be black or brown
2 - switched live feed (low speed)
3 - switched live feed (intermede speed)
4 - switched live feed (high speed)
4 - live feed for parking
or find out which car its from & follow the wiring diagram.
Enjoy.
MB
posted on 12/1/03 at 09:31 AM Reply With Quote
Bob,
I got the motor from Sommerford Mini, who were very helpful. See www.somerford-mini.co.uk
The motor costed about £45
MB
posted on 12/1/03 at 09:36 AM Reply With Quote
Ian,
Just looked at that website you suggested:
That was exactly the information I needed!
bob
posted on 12/1/03 at 10:43 AM Reply With Quote
Thanks MB
Last quote i got new was £60 so thats a good improvement.
locodude
posted on 12/1/03 at 02:41 PM Reply With Quote
Bob
Mine cost about £45 from a Mini specialist about 5min drive from MK. When you get one make sure it includes the rack and spindles and you'll also have to decide which side you want it to park on.
bob
posted on 12/1/03 at 04:48 PM Reply With Quote
Cheers for that chris,i'll get there number when i visit.
zetec
posted on 13/1/03 at 09:22 AM Reply With Quote
If I order a new motor do I get to spec what size (number of teeth) drive wheel is fitted? And if so any idea which combination of drive/wheel box works best? Is there any advantage to which side they park?
bob
posted on 13/1/03 at 07:42 PM Reply With Quote
One of my build guru's tells me the wheel boxes should be the late ones with 110 degree sweep.
stephen_gusterson
posted on 13/1/03 at 08:15 PM Reply With Quote
wondering why, in a locost scenario, peeps are buying mini bits? There must be a load in breakers?
atb
bob
posted on 13/1/03 at 09:13 PM Reply With Quote
Been looking in the breakers,not found a good one yet.And in the south if you do find one they want 30 quid for the lot,so £45 seems a good deal for new.
James
posted on 15/1/03 at 12:19 PM Reply With Quote
Hi Mate,
For the less mini knowledgeable amongst us:
What reg is a late one ie. what should I be looking for in the scrappie?
James
bob
posted on 15/1/03 at 06:58 PM Reply With Quote
Shiney one,LOL
Or maybe mini mayfair,as late as poss as early mini's only single speed.
