Author: Subject: tail wires complete, almost
derf
posted on 24/10/05 at 01:30 PM Reply With Quote
I just need to ground the trunk harness. I left the ground wire long (the black wire curled up). I also dont have a fuel cell yet, the bright wires hanging in the center will go to that, and one of those goes to the 3rd brake light, which I avnt figured out where it goes yet either...
Before the car is done I am going to go back and loom the whole harness to protect the wires from chaffing.
rear lights wired up
_Aero_
posted on 24/10/05 at 02:04 PM Reply With Quote
Don't forget the license plate wiring, which is connected to the same circuit as the tail lights m8... can't see any Are those lights less than 400mm from the other edge - do the same rules apply for USA SVA as our UK SVA?
[Edited on 24/10/05 by _Aero_]
derf
posted on 24/10/05 at 02:31 PM Reply With Quote
No not even close, SVA is of no concern here, each state regulates their own type of SVA, which is quite easy to get around...
I have another curled up wire hidden from view (behind the ali pannel) for the plate light and ground, I plan to mount the plate on the right side rear arch, which I havn't fitted yet.
_Aero_
posted on 24/10/05 at 03:32 PM Reply With Quote
Does your se7en have negative or positive ground Derf? I've heard most American Car's have Positive Earth is this still the case? I'm only asking cos I'm nosey!
derf
posted on 24/10/05 at 03:44 PM Reply With Quote
I'm not exactly sure what you mean, but my chassis is -Neg. As far as the chassis being +Pos, thats just a stupid way of doing things, I've never heard of a chassis being +Pos, every time you touch the ground and the car, or something touches the car it would be grounded, and most likely overload the battery and make it explode. I can just picture the fire resulting from that....
My chassis hooks to the -Neg side of the battery....
[Edited on 24/10/05 by derf]
BKLOCO
posted on 24/10/05 at 05:39 PM Reply With Quote
For information only.
Positive chassis/ground cars were commonplace in the 50's and 60's.
I believe the manufacturers switched to Negative chassis to try to reduce the corrosion problems caused by electrolosis...
I'm waiting to be shot down....
tks
posted on 24/10/05 at 05:41 PM Reply With Quote
no thats not true...
Wy should something what hits the ground take power from the battery?
Rule one for electrics, there must be an circuit between the 2 poles...
Sow your battery wouldn't explode...
Tks
posted on 24/10/05 at 07:36 PM Reply With Quote
+ earth
was used on cars fitted with dynamos ( magneto to U.S. residents) I don't know of any alternators using anything but - earth.
