Author: Subject: Premier Wiring's lights? SVA friendly???
garage19
posted on 22/5/06 at 01:22 PM Reply With Quote
I'm looking at buying some of Premier wirings 110mm bottom mount headlamps.
Has any one else used these and passed SVA? Are they considered SVA friendly?
flak monkey
posted on 22/5/06 at 01:46 PM Reply With Quote
Probably not...if they are the same as the GTS ones then a few people have failed SVA with them.
Sera
http://www.motosera.com
posted on 22/5/06 at 01:48 PM Reply With Quote
This has been covered extensively - the 'search' facility is always a great place to start
HERE
nitram38
posted on 22/5/06 at 02:02 PM Reply With Quote
Have a look in my archive (on the car). I have the 5 3/4" budget lamps with a nut at the bottom. I have put one of those nut covers over them both.
I just hope that is enough for sva.
[Edited on 22/5/2006 by nitram38]
flak monkey
posted on 22/5/06 at 02:15 PM Reply With Quote
I would be interested to know if the Saturnus ones shown on the PWS website would pass sva...
Basically they need the correct beam pattern. The ideal lights are E marked and have an arrow that points to the right (to the verge) when you are looking into the light indicating the direction they dip in. However if the lights arent marked then the SVA man will test them to make sure they have the right beam pattern. IIRC the problem with the 4" ones is that although you can modify them to dip to the left, they have no horizontal beam cutoff so they fail...
Sera
garage19
posted on 22/5/06 at 02:21 PM Reply With Quote
The premier wiring webby states:
"Very compact headlamp unit e-marked takes H4 halogen bulb c/w s/lt."
So if they are E marked does this mean they are deffo ok?
flak monkey
posted on 22/5/06 at 02:25 PM Reply With Quote
No, they might be e-marked for bikes which is what the 4" ones are I think. You also need to know what other markings are on the light.
It tells you what all the markings should be in the sva manual i think.
Sera
Humbug
posted on 22/5/06 at 02:26 PM Reply With Quote
Not necessarily... they need to be left-dipping lights. If they are, they have an arrow pointing to the left of the car, or a double ended arrow (indicating that they can be set up for either left or right dipping)...
...AFAIK
nitram38
posted on 22/5/06 at 02:50 PM Reply With Quote
I put these on the car, from premier wiring:
iank
posted on 22/5/06 at 03:00 PM Reply With Quote
So do they have both an e mark and an arrow pointing to the left? (or a left/right arrow, which IIRC means can be converted correctly to LHD/RHD)
£25/pair is a very nice price, are they reasonable quality?
As for the 110mm ones, a bloke was asking about SVA while I was at the premier stand at Stoneleigh and the answer was something along the lines of 'I haven't heard of any problems' which didn't sound like a confident yes. They are very nice looking though.
nitram38
posted on 22/5/06 at 03:19 PM Reply With Quote
They are good for the money. They have integral side lights that means that I do not have to install more lamps!
Bought mine at donnington about 2 years ago. They had left hand pattern only, but the online ones may have different lenses.
BKLOCO
posted on 22/5/06 at 05:32 PM Reply With Quote
To put the record straight:
The lights above in the post from iank
were fitted to my car and presented for SVA.
I had twisted the lense in the housing so that the "kick up" was in the box area on the beam setter.
The inspector failed them because there was no horizontal cut off as stated by Flak.
This all happened at Chelmsford VOSA.
Gillingham VOSA are not so fussy.
I know of at least 3 cars that have passed there with these lights.
My inspector said that had I left the beams flat and not twisted them as long as the hot spot of the beam did not come above the red line on his beam setter he would have passed them as British American headlights which do not have a "kick up" to the left.
I took no chances with my re-test and borrowed a set of Westie lights from a mate.
[Edited on 22-5-06 by BKLOCO]
