paulf
posted on 5/5/03 at 09:20 PM |
Vw fan switches.
I have a polo rad in my car and the fan sensor has three terminals, i assume one is a common and the other two are different set temperatures. Can
anyone confirm this and tell me what set points they are?. I want to use one for the fan and the higher temperature one for a warning light which may
be the original purpose if not for a two speed fan.
Paul.
stephen_gusterson
posted on 5/5/03 at 10:28 PM |
have you metered it?......it may be one is a connection point for summat else and is commoned.
Can it be taken out? if so you could put it in a saucepan and raise temp and see when each terminal switches.
cups of water cool down too fast
atb
steve
highspeeddirt
posted on 6/5/03 at 12:55 AM |
I'm no great expert on wiring so you should check this. The wiring diagram for my VW Jetta shows a switch with three wires as follows
Terminal 2 red/white 95 degres to fan
Terminal 1 red/black 105 degres to fan relay
Terminal 3 red live feed from fuse box
Hope this helps
paulf
posted on 6/5/03 at 08:14 AM |
Thanks thats exactly what i needed to know. I wanted to avoid removing the switch as i was worried about damaging the rad as it appears very tight.I
will use the lower temp for the fan and the high one for the temperature warning light.
The original set up must be for a two speed system and the relay switches out the resistor for maximum speed.
Paul
Hope this helps
