Author: Subject: ZX9R NO SPARK
Chris7
posted on 18/8/06 at 12:50 PM Reply With Quote
ZX9R NO SPARK
ZX9R NO SPARK
Hi
Guys
I have aZX9R C1 does any one know any good wiring guys apart from the oracle steve keenan as he is fully booked
Using a Sierra Ignition and
Orginal bike ignition
Vicky Green Loom
ETB Dash
all the wiring is in and connected
we have no spark / and no power to fuel pump
Does anybody know what the 4 wires out of the bike ignition are connected to as somthing tells me where missing somthing here.
plus me and charlie are getting splinters from scratching our head so any help would be apprieciated thanks Chris
ch1ll1
posted on 18/8/06 at 01:03 PM Reply With Quote
Whats your e-mail addy?
can send you a workshop book in pdf form if its any good
[Edited on 18/8/06 by ch1ll1]
posted on 18/8/06 at 03:07 PM Reply With Quote
From bike ignition IIRC from the 12R
1. Parking Lights
2. Line In
3. Line Out
4. Feed to ECU (after Resistor from bottom of original Kwak Ignition Barrel)
If you don't have this resistor fed (IIRC it's the grey wire) wire you will have no spark and fuel pump wont work.
HTH
Chris7
posted on 18/8/06 at 03:26 PM Reply With Quote
NO SPARK
Hi
so i do need the resistor even with the orginal kawsaki ignition
ch1ll1
posted on 18/8/06 at 03:46 PM Reply With Quote
not if you have the ignition lock (barrel and key) connected to it
badding
posted on 18/8/06 at 05:06 PM Reply With Quote
Hello,
I'm also using a zx9r in my MK indy, don't know if it will help you, but iff you take a look at my website, i've explained how to start the engine.
You could bypass the fuelpump relay and connect the pump directly to the battery..
Have you also shortened the sidestandswitch and neutralwistch...???
badding
posted on 18/8/06 at 05:09 PM Reply With Quote
And yes you need a 100 ohm resistor if youre not going to use the ignition key..
[Edited on 18/8/06 by badding]
badding
posted on 18/8/06 at 05:12 PM Reply With Quote
piccie
Chris7
posted on 19/8/06 at 09:36 AM Reply With Quote
NO SPARK
Hi
Thanks for that
i know have power to the fuel pump
and power to the coils but still no spark
Thanks Chris
