Author: Subject: vicki green loom with nippon denso alternator
jabbahutt
posted on 31/8/07 at 09:24 PM Reply With Quote
Evening
I found my battery completely flat tonight and after several helpful posts on fault finding techniques i believe i know the problem
Here are some posts from flange nut on the subject
The Vicky Green loom uses Brown as the unswitched live and Green as the switched live. White is the ignition live.
I have a Vicky Green Loom and a Nippon Denso alternator. The problem is that the field coils of the alt are permenantly connected to the battery (thin brown wire). I had to modify my loom to use a switched live feed.
Being an electrical fool this means very little and i don't know how to rectiy the problem. I've U2U flange nut for assistance though any info from anyone else much appreciated.
Nigel
COREdevelopments
posted on 31/8/07 at 10:06 PM Reply With Quote
i got a wire diagram for a toyota 4age alternator which i believe to be a denso unit, il try and get it uploaded for you.
rob
posted on 1/9/07 at 05:55 AM Reply With Quote
Hi Nigel,
Not sure if it's exactly the same alternator, but definitely a Denso one so these pics may help.... Rescued attachment img_11.jpg
posted on 1/9/07 at 05:57 AM Reply With Quote
jabbahutt
posted on 1/9/07 at 08:32 AM Reply With Quote
Thanks for the help
Nick with it wired as it is did you have any problems with battery drain? That's how mine is wired and the battery flattened witihn 4 days.
did you have to modify the loom at all?
Nigel
[Edited on 1/9/07 by jabbahutt]
martin1973
posted on 1/9/07 at 05:41 PM Reply With Quote
get a 12v bulb, a piece of wire,
remove the positive battery lead
connect the bulb to the positive lead and to the postive terminal on battery
if the bulb lights something is draining current.
to work out what is drawing current disconnet each component in turn.
martin
posted on 3/9/07 at 01:43 PM Reply With Quote
Nigel,
I don't recall making any mods to the loom for the alternator wiring. Although I did wire it up incorrectly at first which caused a current drain - IIRC I had the charge warining light wired up wrong somewhere along the line.
