Author: Subject: Rubber Grommets
stuart_g
posted on 8/1/08 at 04:21 PM Reply With Quote
Rubber Grommets
I need to get a rubber grommet like the one in the pic but I can't find anywhere to get one from. Does anyone know of anywhere? I have tried the usual VWP, CBS, SVC e.t.c, e.t.c Rescued attachment P1000366.JPG
Guinness
posted on 8/1/08 at 04:29 PM Reply With Quote
Polevolt do them, on page 4 of the catalogue, I think.
HTH
Mike
worX
posted on 8/1/08 at 04:30 PM Reply With Quote
What size is it? ID & OD. And do you just want one?
I'm not sure I'll have one tht size, but I have a pack of Misc sized ones, will look for you in a min.
stuart_g
posted on 8/1/08 at 04:42 PM Reply With Quote
It doesn't have to be the same size as the one in the pic, just the same style. I need it to go over plastic convoluted sleeving which is 15mm diameter. It also needs to be fairly stretchy as I have a couple of plugs to go through it aswell.
martyn_16v
posted on 8/1/08 at 10:55 PM Reply With Quote
I'd go and salvage one from the scrappy, there'll be loads to choose from
posted on 10/1/08 at 10:28 AM Reply With Quote
have a look in maplins - the do a selection of grommets; or a blanking grommet and cut the hole size as required.
