Author: Subject: A couple of electrical questions :D
Johneturbo
posted on 8/2/08 at 02:05 PM Reply With Quote
I'm just trying to wire up my savage hazard switch. OH what fun it is!
as i need a few wires would this be ok for them.
http://www.maplin.co.uk/Module.aspx?TabID=1&ModuleNo=70&doy=8m2
Also an SVA question.
i was going to put the switch on the tunnel cover, would that be ok?
or does it need to be in line of sight
muchly thanks
Mr Whippy
posted on 8/2/08 at 02:28 PM Reply With Quote
? just what are you going to do with all that wire???
all the hazard does is link the two indicator circuits together and connect them to the relay. You can use one of mordern relays that either have a constant flash rate regardless of load or have the hazard function built in.
Johneturbo
posted on 8/2/08 at 02:56 PM Reply With Quote
oh,
i was going by this HERE
have i made it more complicated than was needed!?
the savage switch has eight connections, but i was only going to wire Just the 7
[Edited on 8/2/08 by Johneturbo]
Johneturbo
posted on 8/2/08 at 03:30 PM Reply With Quote
Thanks for the diagram, your way does make it look easier, i've already got relays as they came with the MNR loom.
Is that relay on a perm live then? so that the indicators work with ignition off.
i'll give it ago your way and see what gives
stuart_g
posted on 8/2/08 at 03:44 PM Reply With Quote
John, just out of interest, why are you not using the hazard switch on the column?
Mr Whippy
posted on 8/2/08 at 03:46 PM Reply With Quote
just a bit, this is the layout I use it’s very easy. I have left out the small additional wiring to light the switch and the indicator warning lights for clarity. I also forgot the two diodes otherwise both sides come on at the same time when using the indicators This is the type of relay to use -
http://www.cartestsoftware.com/fz1/tridonep37installation.html Rescued attachment wiring2.JPG
Johneturbo
posted on 8/2/08 at 05:11 PM Reply With Quote
hmmm diodes, my extra wiring technique didn't need diodes, when i tested it
Stu, no real reason i just bought some savage switches. i did read somewhere that the sierra hazard switch can get in your line of sight.
and i like to make life difficult!
posted on 8/2/08 at 05:56 PM Reply With Quote
If it gets in your line of sight either you're scuttle is seriously low or you've seriously short and sitting very near the steering wheel!!!!!
snapper
posted on 8/2/08 at 07:15 PM Reply With Quote
I eat to survive
I drink to forget
