mickebo
posted on 6/9/08 at 03:20 PM |
Sierra LSD again
Looked around here for the possibility to use non LSD driveshaft on my "new" LSD.
Found no real solution.
I have a non LSD on the car, it´s a 3,62 from a 2,0DOCH -92 Sierra, got a 3,62 LSD from a Sierra Cossie ca -91. Got extra shafts from 2,DOCH but no
Cossie ones.
Same diameter and splines inside the diff but different length - no fit!
Found out that there are 25 splines on a non LSD shaft (the shaft not joint) and 25 splines inside a Granada/Scorpio inner/outer joint. And they
fitted perfectly!
Just bought 1 used Scorpio shaft cause inner and outer joint is the same one.
Now I had 2 Driveshafts with outer tripodjoints and screwed inner joints. And it seems all lengths are ok.
Winter project will be to fit the LSD without removing driveshafts from my new wheelbearings, just to change the innerjoints.
mickebo
posted on 6/9/08 at 03:21 PM |
No fit
mickebo
posted on 6/9/08 at 03:22 PM |
Same thickness on tripod vs joint
mickebo
posted on 6/9/08 at 03:23 PM |
Fit great on splines
mickebo
posted on 6/9/08 at 03:25 PM |
Think I will use the spring from the tripod to position the joint
mickebo
posted on 6/9/08 at 03:26 PM |
2 "new" shafts and som maybe useful scrap?
mickebo
Measuring
mickebo
posted on 6/9/08 at 03:27 PM |
After some refurbishing it´s going to sit here!
Volvorsport
posted on 6/9/08 at 03:43 PM |
are you from sweden ?
whats the diameter and spline count in the diff - is it 25 ?
youve got a 7.5inch diff ,how many bolts does teh crownwheel bolt to the diff housing with ?
do you have a dimension from the crownwheel face to the bearing race ?
www.dbsmotorsport.co.uk
getting dirty under a bus
MikeR
posted on 6/9/08 at 03:45 PM |
where are you based? I could be interested in your left over bits for my de-dion install. I'm having to have shafts made up and any spares in
case the job goes wrong would be appreciated.
mickebo
posted on 6/9/08 at 03:51 PM |
Yes I´m in Sweden.
No it´s a 7inch diff.
To far MikeR?
Volvorsport
posted on 6/9/08 at 05:30 PM |
well the big question was , if its a 10 blot CWP , it may be able to modify it to my volvo rear axle , altho that has 27 spline dana 30 .
MikeR
posted on 6/9/08 at 06:11 PM |
quote: Originally posted by mickebo
Yes I´m in Sweden.
To far MikeR?
Got friends in Helsinki and Oulu, may pop round when i next go to see them
(ok, its too far)
mickebo
posted on 6/9/08 at 08:21 PM |
10 blot CWP?
What Volvoaxel are you using?
You want to fit a Sierra LSDunit in your Volvoaxel?
Number of bolts and diam. of crownwheel?(maybe 7inch)
Number of splines into diff + diam.?
I don´t understand this:
"do you have a dimension from the crownwheel face to the bearing race ?"
I´ll goto my workshop tomorrow and check it, i´ll be back.
mickebo
posted on 7/9/08 at 11:04 AM |
10 blot CWP?
Number of bolts and diam. of crownwheel?(maybe 7inch) 10 bolts
Number of splines into diff + diam.? 26 splines ca 28,5 mm
"do you have a dimension from the crownwheel face to the bearing race ?" maybe 35 mm
Look in my photoarchive, rearendbook might be some tips.
Why did you believe I was Swedish?
[Edited on 2008/9/7 by mickebo]
