Author: Subject: Dipped and main beam
MK9R
posted on 14/1/04 at 04:17 PM Reply With Quote
I've got the headlights on a relay, but this is before the stalks for the dip and main beam. Can a sierra stalk handle this???
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
posted on 14/1/04 at 04:32 PM Reply With Quote
Is the relay live all the time as it sounds you are using it for the wrong purpose. I can't see how the Sierra switch will stand up to carrying the full current for the lights if you use them a lot as it only supposed to switch the relay. You may as well not have the relay in as it is wired at the moment.
yours, Pete.
Mk-Ninja
posted on 14/1/04 at 04:41 PM Reply With Quote
Austen
If you wire it in as per the bike wiring diagram ie switching the relay then it will be OK.
Gordon
PS Ive sent you Email
I'm sure I've got one, just don't know where I've put it
