Robbo202
posted on 25/6/20 at 03:07 PM |
Haynes book amendments
Afternoon All,
New member here, and about to finally start building a Haynes Roadster after about 12 years of thinking about it.... the stars have aligned,
I've got the space, the tools, and a bit of time..!
First things first, the Haynes Forum used to have a link to the PDF of amendments to the Haynes book - it no longer seems to be working though (the
link that is). Does anyone on here have a copy they could share, or repost?
Apologies if on here already, but certainly couldn't find it.
There were also some PDFs with some build guides for certain parts... anyone got those?
The links are here:
http://forums.haynes.co.uk/showthread.php?t=2430
Thanks in advance
ianhurley20
posted on 25/6/20 at 03:26 PM |
If you go to the last page of that thread Sylvain Vought has posted a link to all of them in his own google drive. Copied here
https://drive.google.com/drive/folders/0B-iOekLVikV5c2xSRXZCdElrSEU
voucht
posted on 25/6/20 at 05:33 PM |
You've been quicker than me to reply Ian, thanks!
Robbo202, the link is actually also on last page of the Haynes Forum posts you give the link to.
http://forums.haynes.co.uk/showthread.php?s=3e
b2359b408329d490041fcd8cc0d70e&t=2430&page=5
Good luck with the build
555
MikeR
posted on 25/6/20 at 06:49 PM |
Might be worth repeating the detail here. Once in a while stores go round of the Haynes forum closing.
voucht
posted on 25/6/20 at 09:04 PM |
That is the reason why the details are hosted on my Google Drive now, which is absolutely not dependant on the Haynes forum. It is always available,
and will be even if the Haynes forum closes down definitely. That was the purpose.
I was just pointing out that the link to the page on my google drive which hosts the documents has been published at the end of the "Book
Amendments & Extra Guides" thread on the Haynes forum, so it can be easily found just by going at the end of the thread (as long as the
Haynes Forum is up and running of course)
Now thanks to Ian, the link it is on this current thread on this forum (LCB) too
And to be honest, even if I like this forum (LCB), it is definitely not well designed to host documents! See how bad the picture hosting/publishing
function is... So I wouldn't even know how to have the documents hosted here, or if it is even possible! But of course, if there is an easy way,
I would be happy to do it
555
Robbo202
posted on 26/6/20 at 07:16 AM |
Thanks all, time to get cracking!
