yellowcab
posted on 6/6/15 at 07:08 AM |
6m x 3m Pop-Up Race Awning (TFH Gazebos)
It's a 3m x 6m Royal Blue 'Series 30' pop-up Gazebo with a set of 4 Royal Blue Sidewalls= (two with windows)
Below is the spec from the web-site, bought from TFH Gazebos and its used 4 times
4x 13.5kg ground weights included.
£375
From the site:
What's Included:
* 3m x 6m Pop Up Gazebo
* Set of (4) sidewalls
* Carry bag with wheels for frame
* Carry bag for side walls & roof cover
* Guy ropes and stakes
* Instant pop up gazebo
* Can be set up in two minutes with no tools required
* Strong steel frame powder coated white
* High quality waterproof PVC backed fabric
* Set of (4) sidewalls, two 3m blank sides, one 6m with two zip up 1.5m wide doorways and one 6m with two windows and window blinds.
* All sides zip together
* Sidewalls are interchangeable
* Quick fit velcro system for attaching sides to roof cover
* Double layer fabric to internal corners of roof cover for extra strength
* UV Resistant and fire retardent fabric
* Quick release pull pin mechanisms
* 3 stage height adjustable legs
* Heat sealed mutli stitch seams for waterproofing
* Reinforced glass nylon brackets
* All framework constructed with nuts and bolts making it easier to replace parts if necessary
* All parts replaceable
* 1 year manufacturers warranty against defective parts
* 1mm gauge 30mm square section steel legs
* 320gsm PVC backed polyester fabric
* Gazebo frame size when folded 156cm high x 51cm x 27cm
* Gazebo frame and roof cover weigh approx 50kgs
* Sidewalls weigh approx 12kgs
yellowcab
posted on 25/6/15 at 04:51 PM |
Back to the top
yellowcab
posted on 12/7/15 at 05:17 PM |
Still for sale
garybee
posted on 19/7/15 at 01:09 PM |
Hi, how much are you asking for this please (the price in your post seems to be the same as for a new one so assuming not £375)?
yellowcab
posted on 20/7/15 at 04:03 PM |
Now sold
