Author: Subject: Through radiator spring loaded fan fittings
r1_pete
posted on 23/7/19 at 06:39 PM Reply With Quote
Is anyone using a fan fitted with the spring loaded rods which go through the rad fins??
Any issues? Iím a bit sceptical, for fear of radiator damage.....
HowardB
posted on 23/7/19 at 07:05 PM Reply With Quote
the man on the Binky video said that they were fine - the plastic clip things - I am sceptical too and used a brace as well,..
Howard
number-1
posted on 23/7/19 at 07:07 PM Reply With Quote
Ive used them on a single seater with 1 rad in either side pod and they were fine. No damage at all and did the job well.
big_wasa
posted on 23/7/19 at 07:39 PM Reply With Quote
I threaded some thin silicone pipe over the ties, binned the springs and used the foam pads.
Depends on the value of the rad but I would use them again.
40inches
posted on 23/7/19 at 07:53 PM Reply With Quote
Used them on 3 rads without a problem, although on all three I made sure the fan was resting on the lip of the bottom tank, not hanging by the clips.
r1_pete
posted on 23/7/19 at 08:19 PM Reply With Quote
Thanks all, Iíll give them a try, I can rest it on the bottom lip too so theres now downward pull, I like the silicone hose idea too.
ianhurley20
posted on 23/7/19 at 08:30 PM Reply With Quote
I've used them on an MX5 fan onto a VW polo rad and on an ST170 engined car with a bespoke aluminium rad and gave one set to a friend who usd them on a race car all with no issues at all.
My build blog http://ianhaynes20.wordpress.com IVA passed 3/10/16
written off 23/9/18
Aug 2019 completed Tiger Avon with ST170 on TB's
Now restoring 1968 Ginetta G4
And - a series 1 Land Rover - don't ask why!
posted on 24/7/19 at 09:46 AM Reply With Quote
I've used them before without problems (road car). I'd be more sceptical using them on an off road vehicle where they could come under extra load/force.
