New Topic New Reply
Author: Subject: pinto heater
YOUSAY54
posted on 31/8/19 at 10:58 AM Reply With Quote
pinto heater
Hi need some help the heater in my Marlin wont turn off on hot all the time, would be ok in winter but nit in hot weather, had a look cant see anything wrong, my question can join both water pipes together and do away with the heater? the engine is 1600 pinto 1991, has a water heated inlet manifold, many thanks.
SteveWalker
posted on 1/9/19 at 03:02 PM Reply With Quote
Yes, joining the ends together should work, but you can get a cable operated changeover valve to do the job:
https://tinyurl.com/London-taxi-heater-valve
I can't tell if the following works in the same way, but it does look like a diverter valve:
https://tinyurl.com/Ford-KA-heater-valve
New Topic New Reply
