Author: Subject: Pedal Box Ratio's
omega0684
posted on 21/3/10 at 06:59 PM Reply With Quote
Pedal Box Ratio's
i was just having a gander through the Rally Design website and drooling away as usual when i cam across these two pedal boxes.
Pedal Box 1
Pedal Box 2
The first has a ratio of 5:1 & the second has a ratio of 6.25:1, but i don't understand what there ratio's are for?
Can someone please explain what they are for?
r1_pete
posted on 21/3/10 at 07:09 PM Reply With Quote
Ratio of the stroke of the foot pedal in relation to piston travel, or cable pull.
omega0684
posted on 21/3/10 at 07:18 PM Reply With Quote
so the piston moves 1 cm when the pedal moves 5 cm?
[Edited on 21/3/10 by omega0684]
posted on 21/3/10 at 07:57 PM Reply With Quote
Very difficult to get a decent pedal ratio in any Seven style car even with top hinged pedals.
Even if long pedals are used to get a high pedal leverage ratio the true mechanical advantage depends on where the drivers foot makes contact with the pedal pad.
[Edited on 21/3/10 by britishtrident]
omega0684
posted on 21/3/10 at 08:17 PM Reply With Quote
So what would be best to go for the 5 or the 6.25?
matt_claydon
posted on 21/3/10 at 10:07 PM Reply With Quote
Without knowing anything about the rest of the brake system (master cylinder piston sizes, caliper piston sizes and quantity, brake disc diameter) that's rather like asking how long a piece of string is!
However, without a servo most people are looking for the most braking they can get from a given pedal force. You should therefore go for the longer pedal (6.25); the compromise is you will end up with a bit more travel.
posted on 22/3/10 at 01:03 PM Reply With Quote
You need to check the dimensions first other wise you could find you are operating the pedals with your heels --- a rather over priced mistake.
Rod Ends
posted on 22/3/10 at 02:03 PM Reply With Quote
you can find dimensioned drawings at the wilwood site.
