Author: Subject: brake fluid warning light on remote reservoirs
omega0684
posted on 23/3/10 at 05:52 PM Reply With Quote
evening all,
i am looking to transfer my single brake fluid reservoir, which is currently mounted to the scuttle, to two separate individual reservoirs to allow for an interchangable scuttle system [one with screen and one without - don't ask for details, its a long story]
i have been looking at these wilwood master cylinders, 0.75 for front calipers and 0.625 for rear
http://www.rallydesign.co.uk/popup_image.php?pID=4053
i have a question regarding the low level brake fluid warning light.
Do you have to have one to pass MOT? if you do, can anyone offer up idea's on how you would install one with these cylinder reservoirs?
cheers
prawnabie
posted on 23/3/10 at 05:55 PM Reply With Quote
Im sure you just have to be able to show the light is working.
doddy
posted on 23/3/10 at 05:56 PM Reply With Quote
you can use this
http://www.cbsonline.co.uk/brake-fluid-reservoir-cap-flcap-129-p.asp
omega0684
posted on 23/3/10 at 05:57 PM Reply With Quote
Originally posted by doddy
you can use this
i have one of those on my current reservoir but doubt it will fit the wilwood ones even if it was separated
[Edited on 23/3/10 by omega0684]
doddy
posted on 23/3/10 at 06:08 PM Reply With Quote
they fit on my girlin res pots
posted on 23/3/10 at 06:36 PM Reply With Quote
Yup, they sure do Same on mine. they're standard Ford parts btw, any brake fluid level sensor of an old Ford will fit...
bigfoot4616
posted on 23/3/10 at 06:52 PM Reply With Quote
mine used to pass its MOT without one so i don't think it is needed, although probably a good idea to have one if you can
[Edited on 23/3/10 by bigfoot4616]
posted on 23/3/10 at 07:31 PM Reply With Quote
Save a lot of money
Clutch mastercylinder for series 3 Landrover 0.75" bore
http://www.paddockspares.com/pp/SERIES/Clutch/Clutch_master_cylinder-S111.html
http://www.landroverspares.co.uk/product.html?cpdID=468
adithorp
posted on 23/3/10 at 08:15 PM Reply With Quote
I think you might have that ^^^ the wrong way around.
I've never seen the fliud level sensor checked at MOT.
adrian
http://jpsc.org.uk/forum/
cd.thomson
posted on 24/3/10 at 09:08 AM Reply With Quote
Yes those are the sizes dax supply as standard with their pedal boxes. 0.625 is the m/c for the front circuit.
adrian
Craig
