Author: Subject: Machinist advice/help?
bassett
posted on 19/4/10 at 09:56 PM Reply With Quote
Hi, i am pretty sure my hub has minor run out issue and i could do with some help with checking and rectifying if possible/recommended. I dont suppose anyone is in the trade to do this cheaply or can recommend somone who deals with issues like this. The unit is only around £100 with all the components (races/studs fitted) so it has to be cost effective. It is a light weight style alloy hub anodised black to fit MNR's cortina based uprights which uses tappered roller bearings. If anyone can help please u2u me and if your local to m25 jct 6 even better.
Adam
clairetoo
posted on 20/4/10 at 05:54 AM Reply With Quote
I'm not exactly local , but checking / skimming an alloy hub is a ten minute job (allthough any machining needed would remove the anodizing)
If no one nearer offers , could you bung it in the post ? I'd do it for a drink
Its cuz I is blond , innit
Claire xx
Will weld for food......
