Author: Subject: Reverse Bleeper on truck
gavin174
posted on 10/6/12 at 05:05 PM Reply With Quote
Afternoon All
I have just bought a 7.5 tonne race truck and want to fit a reverse warning bleeper.
I have got a durite 24v bleeper that I can wire into the reverse lamps,
but i would like to do it so if the side lights are on the bleeper does not work.
can I wire the live to the reverse lamps and the earth throught a relay controlled by the sidelights,
so that when the sidelights are on the earth is disconnected
if so can anyone recommend a 24v relay and help with a wiring diagram please
thanks in advance
Gavin
philw
posted on 10/6/12 at 05:18 PM Reply With Quote
Would it not be easier to put a manual overide switch on the dash somewhere? so you can switch it off if necessary.
Must try harder
gavin174
posted on 10/6/12 at 05:26 PM Reply With Quote
I could run override switch to dash.. But means running cable the length of the truck
And then allowing for the tilt of the cab etc
Just thought it would be easier to have an automatic override, can't forget it that way
posted on 10/6/12 at 05:34 PM Reply With Quote
Have a look at the Durite catalogue IIRC they list various relays some of which may do the job but not sure if they are available in 24v
Hector.Brocklebank
posted on 10/6/12 at 05:37 PM Reply With Quote
All our new trucks at work have a manual override switch in the dash for the reverse siren, which according to both Mercedes and MAN is a technically superior way do things, they use a two core wire switching live, the reason for this is that the switch can have a tell tale on it.
And running a cable up to the dash allowing for cab tilt is not an issue, you just insert it in the conduit that's already there, as most manufacturers wire in empty conduit on the production line just for the insertion of accessories.
Some people can never handle the truth and always try to shoot the messenger instead of taking an honest look in the mirror (its always easier to blame another than to face reality), but secretly they wish they could grow a pair and be the messenger !!!
stef030
posted on 10/6/12 at 06:05 PM Reply With Quote
all our trucks have a override switch in the cab,
I think its illegal to use after 10 pm the same as a car horn
cheers
stef
that bit is flat out fella
jacko
posted on 10/6/12 at 06:08 PM Reply With Quote
If i remember right the revers horn must be turned off between 11pm and 730 am by law so if you reverse at 6am light mornings no lights on then the horn will work
All buses have over ride switches fitted for this reason
balidey
posted on 10/6/12 at 06:25 PM Reply With Quote
Most reverse bleepers we have fitted to our trucks come as 'night silent' as standard, there is a reverse and a sidelight feed.
It is as you say just a relay built in to the bleeper.
Dutch bears have terrible skin due to their clogged paws
gavin174
posted on 10/6/12 at 06:40 PM Reply With Quote
thanks all
this seems the easiest way to do it, but the durite bleeper only has 2 wires so i need to get the relay separately....
seems the easiest way to do it, as if i want to turn it off i only have to turn the sidelights on...
sm1ggles
posted on 10/6/12 at 07:46 PM Reply With Quote
you can get a 3 wire reverse bleeper one to reverse and one earth the other goes to the side light no relay just bleeper and 3 wires should be in any durite or ttc book
paulf
posted on 11/6/12 at 09:46 PM Reply With Quote
That seems a bit strange to me , never realised that reverse warning sounders don't work at night.Presumably its ok to run someone over at night when it is harder to see them in the way?
Paul
blakep82
posted on 11/6/12 at 09:58 PM Reply With Quote
Paul
yeah, just don't wake them up while you do it
________________________
balidey
posted on 12/6/12 at 09:06 PM Reply With Quote
Statistically you're more likely to get hit by a truck going forwards, but they don't bother having a warning bleeper for that.
steve m
posted on 12/6/12 at 09:12 PM Reply With Quote
"That seems a bit strange to me , never realised that reverse warning sounders don't work at night.Presumably its ok to run someone over at night when it is harder to see them in the way?
Paul"
+1 , i was thinking the same!
coyoteboy
posted on 13/6/12 at 01:48 PM Reply With Quote
Cant recommend a relay for you, 24v ones must exist somewhere and I'm assuming you have an all-24v system on the truck, so here's your diagram...excuse the use of paint!
Reverse beeper disconnect
