Author: Subject: Duratec Oil Filter Options
davidimurray
posted on 4/7/14 at 02:30 PM Reply With Quote
I see a few suppliers selling adaptors to use a new spin on oil filter but generally seem to be around £100 which seems a lot of money for a bit of Ali!
I was wondering about knocking one up myself - I have a CNC mill so that side isn't a problem. has anyone made their own?
Also does anyone happen to know what spin on oil filter raceline use?
Dave
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
DW100
posted on 4/7/14 at 02:52 PM Reply With Quote
Fiesta ST150 (2.0 Duratec) uses a screw on filter as standard.
Filter housing is bolt on.
Filter part No. is 1751529
[Edited on 4/7/14 by DW100]
DW100
posted on 4/7/14 at 03:03 PM Reply With Quote
Just looked at the Raceline one, it comes out horizontal, the Fiesta ST150 one the filter hangs downward.
edthedrummer
posted on 4/7/14 at 04:05 PM Reply With Quote
I'm going to machine my own in my manual mill so will be interested to see how this goes!!
davidimurray
posted on 4/7/14 at 06:05 PM Reply With Quote
Won't be starting for a while, was just throwing a few ideas around. Which oil filter are you planning to use?
se7ensport
posted on 4/7/14 at 07:41 PM Reply With Quote
I use K/N HP-2009.
It is designed for the duratec so its pressures release valve is at the correct PSI.
eBay Item
[Edited on 4/7/14 by se7ensport]
GreigM
posted on 5/7/14 at 08:25 AM Reply With Quote
I just went through this dilemma myself.
The engine builder of my car fitted it with a Mann+Hummel W7008 which has a bypass valve which opens at 1bar. I'm running about 265bhp with no problems.
Caterham (on R400/R500 duratecs) use a UFI 23.118.00 which opens at 0.7 bar (and is quite a compact unit - they might be using it for size as much as anything else).
The KN above is rated to open between 11-14psi which is 0.75-0.96 bar, so I'm guessing anything of decent quality in the 0.7-1 bar range will probably do the job.
itsawindupuk
posted on 6/7/14 at 07:51 AM Reply With Quote
Ive been using the Halfords HOF200 for a few years now without any problem. With my trade card its only £1.50
davidimurray
posted on 6/7/14 at 09:07 AM Reply With Quote
Thanks everyone, lots of great information there.
