Author: Subject: Coolant pipe hard to soft connectors
ChrisW
posted on 6/3/18 at 12:52 AM Reply With Quote
Anyone come across one of these connectors leaking before? As you can see, mine is (on the Jeep)....
Coolant line
Coolant line
Can the connectors be replaced/re-sealed 'in situ' or does the whole line need to be replaced?
(Note the jubilee clip is where the LPG system has been T'd in, nothing to do with what I am asking about)
Thanks, Chris
My gaff my rules
melly-g
posted on 6/3/18 at 08:01 AM Reply With Quote
That looks more like a hydraulic fitting!
Can the end be removed then just normal jubilee type clamp used in its place?
CosKev3
posted on 6/3/18 at 08:58 AM Reply With Quote
As above that's a swaged fitting,so it's been pressed to seal with a few tons of press.
If it's a massive job to replace the pipe I have seen people bodge them by cutting them out,then as above use a piece of rubber pipe with hose clips.
Hardest part doing that will be flaring the end of the steel pipe to stop the rubber one sliding off,couple of small blobs of weld will work if the pipes thick enough
40inches
posted on 6/3/18 at 09:21 AM Reply With Quote
The pipe will have 2 flares on already. One the normal flare on the end plus a smaller flare that acts as a stop for the flexi.
I would push a new piece of flexy over both flares and use 2 hose clips, one either side of the second flare
[Edited on 6-3-18 by 40inches]
CosKev3
posted on 6/3/18 at 09:26 AM Reply With Quote
That depends if he can can remove the swage part without damaging them
Just cut straight threw the pipe about a cm away from the swage end is the easiest, and gives you a longer piece of rubber pipe to work with
Mr Whippy
posted on 6/3/18 at 12:08 PM Reply With Quote
what's in the pipes and leaking out? looks more to do with the aircon or heater
Andybarbet
posted on 6/3/18 at 10:01 PM Reply With Quote
I'm a hydraulic fitter. They look like crimped ferrules to me which is unusual on a solid pipe.
You could cut the ferruled end off the solid pipe & fit a compression fitting with a barbed hosetail in its place if I am understanding correctly ?
If you can give me the outer diameter of the metal pipe & the inner diameter off the hose I might possibly be able to sort something out.
