<<  1    2  >>
Author: Subject: Project Stella MX
mini-sprite
posted on 18/4/16 at 08:50 PM Reply With Quote
Originally posted by Slimy38
Fantastic build thread, I'm not entirely sure how I've missed it all this time but I'm definitely going to keep an eye on it now!!
One question, the front upper wishbones, they're not very 'triangular' are they? I appreciate there's not much loading meant to go through them, but they do seem to put bending forces on to the weld joints. The lower ones look better as they have bracing on them.
This is indeed a weak spot in my opinion as well and might need to be looked at again. It's a trade off between having enough room for a coilovers to pass through. I was going to weld some round bar to triangulated I will have plenty of testing to do.
Paul
When i buy car parts i go on the premise that 'it is easier to beg for forgiveness than ask permission'
mini-sprite
posted on 9/5/16 at 08:05 PM Reply With Quote
Had a really good few weeks my missus has been away on holiday with her mum so had the long bank holiday weekend and last weekend and the weekend coming
This is the results so far
I love CAD
Diff went in as well
And my nice new coil overs
And finally on floor with the coil overs instead of my temp steel tube
A bit of neg camber
See what else i can do this weekend
Paul
mini-sprite
posted on 18/5/16 at 08:50 PM Reply With Quote
Started on my bulkheads
Rear one will get done this weekend all being well
Paul
mini-sprite
posted on 5/6/16 at 09:39 PM Reply With Quote
Rear bulkhead finished. It just needs sealing around the bottom and around the bars
seat and harness went in as well
Paul
Talon Motorsport
posted on 10/7/16 at 08:48 PM Reply With Quote
Please tell me there is going to be a diff NOSE MOUNT and your not just going to rely on the main plate of the diff cover??? It was not intended to work on it's own the main plate only stops the diff twisting it DOES NOT stop the diff from bucking when you put torque through it!!!
[Edited on 10/7/16 by Talon Motorsport]
woodster
posted on 18/7/16 at 06:34 PM Reply With Quote
Great build thread .... Keep up the top notch work loving every update
<<  1    2  >>
