Bolt on roll cage clamp
Daf - 22/12/13 at 07:16 PM
Hi all,
I'm looking for a clamp of some description to bolt my cage to my roll hoop. The roll hoop is nicely painted so I don't really want to go welding to that but my cage is still under construction, I need something similar to a glorified U bolt or similar - any suggestions welcomed
madteg - 22/12/13 at 07:33 PM
Put( split pipe clamp in google ) There you go.
Daf - 22/12/13 at 08:01 PM
I'd quite like something like this:
http://i622.photobucket.com/albums/tt310/Hemo59/Roll%20Bar/001Clamp.jpg
but it seems to be a company over the pond that supplies them - anybody ever seen a uk supplier of parts like this?
ReMan - 22/12/13 at 08:37 PM
Depends how heavy duty you need and what you want it for, bit also try LIGHTING CLAMP 52mm
Scuzzle - 23/12/13 at 02:15 AM
Not sure if this is what you mean but I used bolt on 3 piece bike frame clamps on my roll cage.
http://www.ebay.co.uk/itm/3-Piece-1-1-2-in-Frame-Clamp-/400409997288?pt=UK_Motorcycle_Parts_13&hash=item5d3a4bafe8
The come in various sizes usually from an inch going up in qtrs to 2.5 inch so fits most roll cage diameters and come in black or chrome. They are not bad to look at either when fitted and won't detract from your cage. I put 2 on my cage as the eyelet hole lines up perfectly with the seat belt hole in the car so I'm using them to add some rigidity further up the cage and to secure my seat belt eyelets.
Daf - 23/12/13 at 03:17 PM
Brilliant - I like those - thanks for you help
Nick DV - 23/12/13 at 05:55 PM
Whatever you use, makes sure it's up to the job! Personally, I'd weld it and make good the area of the weld!
