Engine number
Clive skuse - 17/2/20 at 04:33 PM
Hi everyone I am new to this forum not sue if I am doing this right. My problem is that I purchased a new Zetec engine from gts tuning back in 2006 at the Exeter kit car show , now after the build stalling for a few years I am getting near Iva time but have not got a engine no stamped on the block. I phoned fords but they can’t issue a no because they can’t prove the engine age and suggest l contact the supplier, I have tried to call gts with the number on the invoice but it will not connect. Has anyone got a upto date number for them. If not does anyone know how I can get a engine number,
Thanks Clive
Bluemoon - 17/2/20 at 05:19 PM
Get scrap Zetec block and copy over number?
Ford replacement engines come with out engine number as supposed to replace existing engine. The number is copied as old engine is scrapped..
Dan
pekwah1 - 17/2/20 at 05:21 PM
Hi,
Welcome to the forum!
Firstly i assume this is a blacktop engine?
If so, you will need a CAT to pass the IVA test in any case, from having a quick check in the manual i found this:
“Effective Date”
The “effective date” used to determine the criteria applicable is -
the date of manufacture of the vehicle, except for an “Amateur Built” vehicle, a “Vehicle manufactured using parts of a registered vehicle” or a “Rebuilt vehicle” it
shall be 1 January immediately preceding the date of manufacture of the vehicle’s engine if this is earlier.
If the “effective date” cannot be determined, it must be assumed to be on or after 1 August 1997.
You will be able to prove the latest date of when the blacktop zetec was produced until and so should be able to use this date which would still effectively have the same emissions rules unless i'm mistaken.
I believe GTS finally stopped trading so you likely won't be able to do much there, otherwise i guess if you really need an engine code it will be to get another engine.... if that engine disappeared but the engine number ended up stamped on yours....... you get where i'm going
gremlin1234 - 17/2/20 at 05:26 PM
its quite normal for a ford replacement engine to have no number. it is supposed to take the number from the one it is replacing.
if you have the paperwork for your doner car, you could take the number from there
else, it wouldn't be the first engine recorded with number 1342. (the firing order often stamped on some engines...)
edit
the original engine number should be the last two letters and final numbers of the vin
https://view.publitas.com/burtonpower/2020-catalogue-booklet/page/12-13
if you don't have the vin of the doner, we maybe able to find it from the registration number
[Edited on 17/2/20 by gremlin1234]
mcerd1 - 17/2/20 at 06:02 PM
^^ what he said
Also change the timing belt before you use it
even if its never run they need changed at 10 years - some folk found out the hard way
Clive skuse - 17/2/20 at 07:27 PM
Thanks for advice good tip to replace timing belt , the engine is a replacement for a pinto engine so don’t know if I could use the no from that. I might have a chat with my local engine builder to see if they have a scrap block that I can use.
gremlin1234 - 17/2/20 at 10:12 PM
how are you planning on registering your build?
age related?
Q?
or new?
kingster996 - 18/2/20 at 07:47 AM
The IVA inspector will almost certainly know that a Blacktop Zetec wasn’t fitted to a Sierra and thus can’t be from the 80’s. So you can’t just use a pinto engine number and hope it gets tested as a pinto aged engine.
Crate Zetec engines were made no later than around 2004 so that’s what I’d put as engine age. Proving that might be more difficult, but maybe call your local test centre and ask.
It will then get a “basic emissions test” with a CAT. Can’t recall the figures but fairly easy to pass as long as you are fuel injected and fit a cat.
[Edited on 18/2/20 by kingster996]
Clive skuse - 18/2/20 at 10:35 AM
age related?
Q?
or new?
I think it will be a Q plate
Clive skuse - 18/2/20 at 10:38 AM
Create Zetec engines were made no later than around 2004 so that’s what I’d put as engine age. Proving that might be more difficult, but maybe call your local test centre and ask.
Thanks I thought that would be the case, have had the engine tuned for mot standard
