New Topic New Reply
Author: Subject: in-line bleed screws
smart51
posted on 8/3/09 at 08:18 PM Reply With Quote
What I really want at this time on a Sunday are some in-line bleed screws. Ideally a 16mm aluminium tube with a screw thing in the middle to let the air out. I'd just cut my hose at the highest point in its run and stick one of these in with some hose clips. The problem is I can't find such a thing.
What are they properly called? Where can I get one(or 4)?
Mark G
posted on 8/3/09 at 08:30 PM Reply With Quote
wouldn't be too hard to make them.
Just get a steel tube, weld a nut on top, drill though the middle of the nut through the tube and use a water proof washer on the bolt.
Then after all that paint it a pretty colour and your done.
stevebubs
posted on 8/3/09 at 08:41 PM Reply With Quote
Not sure of the diameter, but my dad's v6 Rover 75 has a coolant hose with built-in bleed screw....
bikenuts
posted on 8/3/09 at 09:05 PM Reply With Quote
Fiats and Alfas have them, or you can make your own with a 15mm copper plumbing T with a radiator bleed insert soldered in the spare leg.
smart51
posted on 8/3/09 at 09:30 PM Reply With Quote
would that be one of these? I'll pop along to B&Q tomorrow to see if they have them, or else it'll be eBay!
posted on 8/3/09 at 09:31 PM Reply With Quote
Have a look on ebay for bleed valves in the kitcar parts section.
Andy B
posted on 8/3/09 at 10:14 PM Reply With Quote
We use an alloy t piece for the bike installs 25mm through bore with a 9mm od spur for a hose which we tap out 6mm and fit a cap head with copper washer onto, looks tidy and works well, got them on the shelf if any use to you
regards
just spotted you need 16mm but I think we have this size as well
[Edited on 8/3/09 by Andy B]
irvined
posted on 8/3/09 at 10:17 PM Reply With Quote
This does the trick for me:
http://cgi.ebay.co.uk/Caterham-Westfield-kit-car-Bleed-Tee-Coolant-Tap_W0QQitemZ300297755880QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash= item300297755880&_trksid=p3286.c0.m14&_trkparms=72%3A1683%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
Bleed Tee
http://irvined.blogspot.com
bikenuts
posted on 9/3/09 at 11:47 PM Reply With Quote
Yup that's the sort of thing
Bluemoon
posted on 10/3/09 at 08:43 AM Reply With Quote
Or Copper plumbing, you can get a 15mm T plus and add a bleed...
Dan
New Topic New Reply
