Author: Subject: Shock Horror!
Daddylonglegs
posted on 18/4/10 at 07:19 PM Reply With Quote
Shock Horror!
Help! I've got GAZ shocks which I bought from Dampertech late last year and they have been on the car for a fair while. The car is still 'in progress' and so the shocks have never been worked other than the odd jump up and down to check clearances etc.
I noticed today when I was fettling the rear panel that the nearside shock was very wet with oil
On further inspection I spotted that about 1/2 way along the piston rod there is a patch of corrosion! looks like 2 rings about 10mm apart and a bit in between on one part, I guess this has knackered the seal?
I took the shock out for further inspection and there appears to be zero resistance as near as damn it when I work it from stop to stop
I'm going to email Dampertech tommorrow, but wondered if anyone can throw some light onto what might have happened?
Really pi553d off though as I thought the end was within sight
JB
prawnabie
posted on 18/4/10 at 07:22 PM Reply With Quote
has the garage got damp at some point and water has sat on the seals?
turbodisplay
posted on 18/4/10 at 07:26 PM Reply With Quote
My Gazstarted to leak without being driven, not the only one to have this problem.
Protech (in the future) for me...
Darren
tomgregory2000
posted on 18/4/10 at 07:43 PM Reply With Quote
GAZ are SHITE!!!!!!!!
That is exactly the same as mine but mine were on all 4 of them!!!!
got them serviced at a cost of £150 for new shafts and seals and 2 of them are FU*KED in less than 1 year and only 800 miles
STAY AWAY FROM GAZ
And dont spend your money getting them serviced just buy some different ones!
MkII
posted on 18/4/10 at 07:46 PM Reply With Quote
A shock absorber that cant cope with a bit of water is about as much good as an ashtray on a motorbike!!!!!!!!!!!!!
tomgregory2000
posted on 18/4/10 at 07:52 PM Reply With Quote
ooooh ashtray on a motorbike, dragons den here i come
posted on 18/4/10 at 07:56 PM Reply With Quote
Got one on mine, next to the washbasin
austin man
posted on 18/4/10 at 07:57 PM Reply With Quote
Call dampertch , the brother in law has had the same problem, they did repair them.
I have Protech fitted and cant praise the shocks and the service enough
Tipster69
posted on 18/4/10 at 08:14 PM Reply With Quote
Slightly Off Topic.
(Im a noobie), the kit I have just bought has AVO coilovers with adjustable dampers, are they any good?
grazzledazzle
posted on 18/4/10 at 08:50 PM Reply With Quote
I binned a set of gaz shocks after less than 1000miles. Only ever had great service and products from AVO.
[Edited on 18/4/10 by grazzledazzle]
flak monkey
posted on 18/4/10 at 08:59 PM Reply With Quote
My Gaz have been fine (gold adjustables) for 8000miles or so, no leaks or problems.
The shafts are plated I think, so shouldnt get corroded that easily.
Maybe things have changed since I bought mine though....
Sera
http://www.motosera.com
posted on 18/4/10 at 09:24 PM Reply With Quote
All down to the quality of the plating!
ashg
posted on 18/4/10 at 10:50 PM Reply With Quote
one of my gaz shocks pissed all its oil everywhere even before i had driven the car. took it down to them and they fixed it in less than 5mins. they have been fine ever since.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Wheels244
posted on 18/4/10 at 11:12 PM Reply With Quote
I had a Protech leak whilst I was still building mine.
Hadn't even driven it
