Author: Subject: Any tips on a making a foam race seat
daniel mason
posted on 3/2/15 at 09:30 PM Reply With Quote
As above.
Any tips on making race seat from 2 part foam? Cheers
[Edited on 3/2/15 by daniel mason]
posted on 3/2/15 at 09:51 PM Reply With Quote
Bin bags, 2 part foam and a helper. And Wear a really really long t-shirt or wrap some kitchen roll around you like a mummy- the foam has a habit of escaping and heading down your builders crack or sticking to hairy backsides. Which hurts when you try and get out.
daniel mason
posted on 3/2/15 at 09:58 PM Reply With Quote
I've got a litre of each and heavy duty bag which is apparently 2 cubic feet? Hopefully that'll be enough! I don't want to be sliding around in the tub.
lsdweb
posted on 3/2/15 at 10:06 PM Reply With Quote
Some good tips here - http://www.sjmmarsh.f2s.com/Caterham/Foam%20Seat.html
There was a good page on blatchat but that seems to have gone.
Oh, and here - http://www.locostbuilders.co.uk/viewthread.php?tid=126158
Regards
Wyn
Trollyjack
posted on 4/2/15 at 08:39 AM Reply With Quote
Hi Daniel
See Steveiow input on this subject wquite a way down this post but lots of info and pictures
Link
TrollyJack
motorcycle_mayhem
posted on 4/2/15 at 09:46 AM Reply With Quote
One piece tyvec suit works well.
Tape covering up the sides (out and in) of the cockpit, sit on a bin bag filled with foam. Pull a beer and sit until the foam sets.
Make sure that you can depress the pedals(!)....
Remove yourself, trim seat where needed and cover in tape.
You must be quite thin!!!!! I wasn't a 17 stone lard arse, but the fit in the standard Force tub was quite snug without a seat. I sat on a camping mat glued to the floor and the rear bulkhead. Shoulders were difficult, the tub was quite narrow at that point.
eddie99
posted on 4/2/15 at 12:24 PM Reply With Quote
Make sure you wear clothes your prepared to throw away.
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
olimarler
posted on 4/2/15 at 01:25 PM Reply With Quote
Don't use bin bags they split.
Use a bivvy bag from a camping supplies they are much tougher.
Oh and get at least another mate to help
Oli
Dopdog
posted on 4/2/15 at 05:19 PM Reply With Quote
Not very locost but you could use a Hans bag seat nice and clean
Sadsy
posted on 4/2/15 at 08:49 PM Reply With Quote
Make sure you measure it exactly, also worth coating the set mold with some resin before you tape it up or it may change shape after a while
daniel mason
posted on 4/2/15 at 10:20 PM Reply With Quote
Thanks for the tips!
How do you stop your backside from sinking straight to the floor and leaving no thickness or strength in the seat base?
