Author: Subject: Vehicles with side feed injectors as standard?
Chaz
posted on 16/11/15 at 07:10 AM Reply With Quote
Hi all,
I'm looking for some 250cc plus side feed injectors and was hoping to find a list of vehicles which has these as standard.
Nissan 200sx
Nissan 300zx
Subarus
Anything else I can look out for?
Theshed
posted on 16/11/15 at 08:04 AM Reply With Quote
I have been looking into this as well as I need to swop from Methanol injectors to Petrol (about half the flow). There are lots of big side feed injectors for SR20DET engines. I would love to find some dimensions and see if there are any common standards.
I will follow this thread with interest.
Myke 2463
posted on 16/11/15 at 09:38 AM Reply With Quote
side injectors
Try this, might help ? http://passionford.com/forum/technical-help-q-and-a/459718-nissan-subaru-injectors-zetec-fitment.html
Be Lucky Mike.
killerferret666
posted on 16/11/15 at 09:52 AM Reply With Quote
i believe MR2 Toyota 3s-GTE engine has side feed injectors
Thats the MR2 mk2. Revision 2 injectors are 440cc and cheaper then the later rev3 injectors which are larger cc and slightly different size.
Building DDR GT4
Miami Gt4 Blog - Click Here
madteg
posted on 16/11/15 at 08:01 PM Reply With Quote
I am running yellow 440cc subaru side fed injectors in a standard ford fuel rail, would think this would be ok for you.
coyoteboy
posted on 20/12/15 at 01:25 AM Reply With Quote
540cc in the latter 3SGTE Engine. Also found in Celica gt4...
I've a couple of sets knocking about if you need any info, I'm looking at converting to 800cc end fed so I've got most bits off just now.
Chaz
posted on 20/12/15 at 08:12 AM Reply With Quote
Thanks coyoteboy but I've made the jump already and chopped the side feed and used it as a boss for the black top rail. It's a bit messy but there we go! Thanks for the help!
