Author: Subject: DeWalt DWP849X machine polisher / buff
flanders
posted on 22/8/17 at 12:01 PM Reply With Quote
Used once, comes with extra 5" backing pad. £110 i can post if required
DWP849X 240v Variable two finger speed trigger allows the user to control the speed of the unit by adjusting the force applied to the switch. Large variable speed dial allows the user to easily change their speed to suit specific applications. Large spindle lock makes accessory changing easy, "Pop off" brushes protect the armature from damage due to worn brushes. Rubber over moulded gear case allows the user to grip the gear case for greater comfort. Supplied with 180mm Hook&Loop packing pad and wool bonnet, bail side handle and a horizontal side handle. Power Input: 1250 Watts No Load Speed: 0-600/3500rpm Max. Disc Diameter: 150 & 180 & 230mm Spindle Thread: M14
