Author: Subject: THAT tool for the 'special' job!
bi22le
posted on 21/9/17 at 07:37 PM Reply With Quote
A bit of fun for you all.
I was in the garage having a beer while working away. I had a new beer to pop.
Soo, what garage tool did I use to pop a lid off of a glass bottle? I used side cutter and nearly cracked the glass! I don't think it was the right tool but it worked.
What the tool should I have used?
What garage tools have you used for non garage jobs?
Please read my ring story:
Benzine
posted on 21/9/17 at 07:50 PM Reply With Quote
Engine crane shrub lifter
liam.mccaffrey
posted on 21/9/17 at 08:24 PM Reply With Quote
I used a 3 foot long 3/8" socket extension bar with blue roll ducktaped to the end to clean up vomit from the house radiator fins.........my toddler had a tummy bug....😑
Build Blog
Build Photo Album
View User's Profile View All Posts By User U2U Member This User Has MSN Messenger
kenton
posted on 21/9/17 at 09:15 PM Reply With Quote
Had to cut through some floor boards, no room for the circular saw so put the blade in my 9" angle grinder. Took some holding but I still have all my fingers!
dinosaurjuice
posted on 22/9/17 at 07:47 AM Reply With Quote
I use side of vice for opening bottles. More satisfying then levering the lid off
posted on 22/9/17 at 07:54 AM Reply With Quote
I used to use my engine hoist to lift this 5" gauge steam locomotive in and out of my trailer - without the hoist it took 2 strong people to lift it, not good when you're trying to lean over the side of the trailer.
The older I get, the better I was...
posted on 22/9/17 at 08:09 AM Reply With Quote
In a similar situation I've used a ring ended spanner to remove a beer bottle top.
Slater
posted on 22/9/17 at 10:07 AM Reply With Quote
Used my car to pull out a stubborn pampus grass shortly after moving in.
[img] Pampus pulled out
Pampus pulled out
[/img]
posted on 22/9/17 at 11:55 AM Reply With Quote
Pampus pulled out
[/img]
Good effort - there's nothing like a bit of engine power put to good use!
