Author: Subject: rear to front pipe size
bart
posted on 30/5/18 at 07:53 AM Reply With Quote
Hi all second question of the day
I have decided to run front radiator cooling on my midi build
what is the best size ally pipe to run back to front. there is no heater take off required
i was thinking 38mm od but would i get away with 32 mm . i will probably use an auxillary pump to help with flow.
is that also required.
BHP about 350 ish
BE ALERT > BRITAIN NEEDS LERTS
