Author: Subject: Wanted Engine and gearbox for Anglia project.
macc man
posted on 21/9/18 at 05:26 PM Reply With Quote
I need an engine and box to fit an Anglia 105E. I would ideally like a Zetec 1.8 or 2.0l but willing to look at crossflow or Toyota engines. A type 9 box or 2000e would be considered. Let know what you have. I live in Macclesfield South Manchester.
Willing to travel to collect. Many thanks Henry.
Ugg10
posted on 21/9/18 at 05:43 PM Reply With Quote
Zetec will fit in the engine bay without bulkhead mids, kits out there for mounting it. It is tight but do able. Exhausts also available. Type 9 box needs some minor surgery on the tunnel. Either replace or if you search there is a mod to just cut a slit in it, move it a bit and fill the gap, looks more stock. Look for Milton (not cheap but fits first time plus will get your money back if you sell) and 105speed for exhausts (aka Neil McCarthy) I would also sign up for the Facebook 105e owners page, lots of knowledgeable people on the anglia wise.
If you fit a new tunnel then the Mazda rx8 6 speed box comes into play with an adaptor plate.
You could go st170 and fit a me100 ecu and bike carbs, kits available from danst. The me100 is a knobbled me212 with the injection disabled, this has full vct control in it and can be upgraded to me212 if you go injection for a firmware update and a few £.
Need to post pictures, it’s the law!
[Edited on 21/9/18 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
Mike Bentley
posted on 22/9/18 at 03:17 PM Reply With Quote
bit for anglia
hi
I have some parts your might be interested in
A 2000e box with 2-1 second gear ratio not sure of condition but I did buy it from a good source (known him for some 30 years)
Lynx singe twin 40 manifold (new)
Twin 40 weber "not off" an Alfa Romeo with trumpets
Twin 40 Weber "off of?" an Alfa Romeo
1300 cross flow (USED)
Crossflow twin choke down draft and manifold
very big valve and worked slightly chambered crossflow head.
reconditioned M16 calipers
Standard 1600e crossflow chambered head
1960dave
posted on 24/9/18 at 11:07 AM Reply With Quote
I have a reconditioned 1600 crossflow a 5 speed type 9 gearbox twin webers and manifold if thats any good to you. Could deluver as you are very close to me.
