Author: Subject: Duratec and pinto clutch
itsawindupuk
posted on 29/12/18 at 05:50 PM Reply With Quote
Hi everyone. I’ve been busy rebuilding my mob gt duratec the past 3 years. It was driving great before with its standard duratec engine but now I’ve rebuilt the car I’m putting in an R500 spec engine in. The trouble is the clutch cover is too thick and the bell housing and slave cylinder don’t allow it to bolt together.
Before I was using an ST150 flywheel with the ST150 clutch cover and focus clutch plate. I’m now using a lightweight flywheel drilled for a pinto style clutch cover. My pinto clutch cover is thicker than the fiesta one. It’s fingers stuck out much further.
Looking at ap racing covers, the pinto one seems thinner so perhaps I have an odd clutch cover, but I can’t find any of the “correct” type in stock anywhere.
Does anyone have any ideas or knowledge on updated pinto clutch covers?
Shooter63
posted on 29/12/18 at 11:45 PM Reply With Quote
I think you will find that AP have stopped making the covers, I wanted to replace mine but have had to shell out for a Helix job instead.
Shooter
big-vee-twin
posted on 30/12/18 at 09:22 AM Reply With Quote
Is there a spacer behind the slave cylinder that can be removed?
http://www.triangleltd.com
posted on 30/12/18 at 09:29 AM Reply With Quote
What flywheel and clutch do Caterham use in their Rs500 ?
snapper
posted on 30/12/18 at 03:37 PM Reply With Quote
Or space out the bellhousing using ally plate
Draw round the bellhousing to engine face, cut and drill
I eat to survive
I drink to forget
itsawindupuk
posted on 2/1/19 at 09:04 AM Reply With Quote
Thanks for the responses everyone. There is no spacer as it's the raceline Bell housing. If I move the bell housing back it will cause the gear lever to be in the wrong place and the distance would need to be about 15mm minimum.
I'll see if I can get the flywheel drilled to accept the other clutch cover I have. Its a turbosport flywheel but I have a raceline clutch cover I got a while back but has different mounting location holes.
