Velocity parts
Jo_nsf - 6/9/19 at 11:55 AM
Hi, I’ve been looking at getting a seven for a while now and getting closer to pulling the trigger. I’ve been looking at a couple of luego’s and having looked on their, now partially redundant, website it’s caused me to question if I come to need any replacement bits am I going to struggle? They state some parts are still available to manufacture, what happens if I need a bit that isn’t? Given that I’m new to seven’s I don’t wish a little misdemeanour to cause the thing to be a write off.
Thanks all. 👍🏼
Irony - 6/9/19 at 12:20 PM
As far as I am aware the current owners still make parts to order.
matt5964 - 6/9/19 at 12:21 PM
Thanks all. 👍🏼
Ben at luego is very accommodating and will have parts made for you is required.
Also the guys at OBP are the other half of luego when they were biased in Peterborough and have the specs so could have items made if needed
Also some items are also used on other kits eg fibreglass body parts like nose cones and bonnet etc
Failing that a good fabricator would be able to replicate an item from seeing the bent one.
Mine is for sale
http://www.locostbuilders.co.uk/viewthread.php?tid=215502
Matt
[Edited on 6/9/19 by matt5964]
Jo_nsf - 6/9/19 at 06:09 PM
Thanks, I'd seen yours Matt, looks awesome however I think I'd definitely be bending things if I went straight to a 220bhp one.
matt5964 - 6/9/19 at 06:13 PM
Well it only goes as fast as you make it go with your right foot...
As it’s NA it’s very progressive and drivable, with lots of mechanical grip.
