Hi guys
I'm sure I didn't dream this but can't seem to find it, someone posted about pivot bolts in 1/2 inch and said they couldn't get
any.
Well, went to see Steve at Fury on Thursday, mentioned I needed some, pulled 2 out of a bin on the wall and gave them to me.
So in short Steve does have them after all
Hope you see this post and you get sorted
Mark
Got mine from Arun fasteners.
Hi joneh (predictive text just called you honey!)
Was it you who asked the original question, as at the moment I'm doubting my memory!
Will keep them in mind if I need anything else
Mark
No not me. Got all my bolts a few years ago.
Changing them, and all other wishbone bolts made a difference Tommy cars handling. It seemed to tighten it all up and gave me more confidence as I had better predictability.
I might be mixing my posts up here - but essentially the Fury Chassis had Metric holes on the Chassis but the MK2 Escort used imperial bushes.
You're left with 0.7mm wiggle room on each bolt which adds up.
I had to ream my Chassis to take the imperial bolts.
Edit - This might not apply to the later Sierra chassis that the OP is talking about...
[Edited on 4/12/17 by joneh]
Originally posted by Markymark
Hi guys
I'm sure I didn't dream this but can't seem to find it, someone posted about pivot bolts in 1/2 inch and said they couldn't get any.
Mark
Hi Martin
Thanks for the reply, glad you got it sorted.
That's why I couldn't find it when I searched, could have sworn it was on here!
At least I'm not going too senile
Mark
Out of interest, what bolts did you change them to?
