New Topic New Reply
Author: Subject: Chassis paint
Hopley89
posted on 20/12/13 at 08:37 PM Reply With Quote
Chassis paint
I looking repaint my chassis over the winter .. But don't want to spray it on as 70% ends up on the floor or my shine new parts
What would be the best brush on paint
Would this be ok or is this to expensive and is there something just as good but cheaper
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_829867_langId_-1_categoryId_255239
jacko
posted on 20/12/13 at 08:47 PM Reply With Quote
Don't use Hammerite its to brittle and chips
Frosts make a good paint for what you want
I cant remember the name but if you do a search you will find it
Jacko
Found it
POR15
http://www.frost.co.uk/brands/por15.html?gclid=CIjUpMnWv7sCFY_MtAodDi0A_g
[Edited on 20/12/13 by jacko]
Hopley89
posted on 20/12/13 at 08:52 PM Reply With Quote
Is this the stuff
http://www.frost.co.uk/automotive-paint/por15-paints/por15-chassis-coat-black-paint.html
Some people have said use normal house gloss ??? I thought that would be brittle as we'll !?
Hopley89
posted on 20/12/13 at 08:55 PM Reply With Quote
£35.74 a litre is expensive tho and I'll need more than a litre !!!
mark chandler
posted on 20/12/13 at 09:10 PM Reply With Quote
Get some plant paint from your local agricultural suppliers, teamac paint is excellent, sticks to anything and is very durable.
posted on 21/12/13 at 01:37 PM Reply With Quote
Didn't need a litre when I repainted my chassis after stripping off the powdercoating Used Hardnose from Frosts as a topcoat , still unchipped after nearly 5 years of use.
posted on 21/12/13 at 01:44 PM Reply With Quote
Ive used Hempathane on mine, its used in extreme off shore environments. Got it from the local paint shop supplier.
NOT CHEAP (min quantity was 5l tins, DOH!) when you combine the correct primer, thinners and what not, but promises to be the best and works out no more than all the others....
http://www.hempel.com/en/products/hempathane-topcoat-55210
renetom
posted on 21/12/13 at 05:00 PM Reply With Quote
Hi
I found the best to be BLACKFRIARS used it on the underside of our kit car
wrought iron gates , use an anti rust primer first & will last for years
wont chip under normal use , of course if you hit it hard enough.
Brewers & most DIY sell it & its reasonably priced, 1/2 ltrs & larger.
There is another which is heatproof for painting barbecue's
which is also very durable , both are eggshell finish similar to powder coating.
Good luck
[Edited on 21/12/13 by renetom]
Hopley89
posted on 21/12/13 at 05:37 PM Reply With Quote
Iv red oxided the hole chassis .. An I'm gonna paint it with
Normal black gloss as its strong durable and other people
Said it had worked a treat so off to the local DIY
43655
posted on 22/12/13 at 10:12 AM Reply With Quote
Epoxy mastic is what i'll be using. very tough, brushes on fine, and dries to a pleasant satin.
Not too cheap though £100/5l although comes in 1l kits too
jacko
posted on 22/12/13 at 12:26 PM Reply With Quote
You say Expensive but how long is the chassis going to last if you bodge the protector ?
Jacko
drt
posted on 22/12/13 at 02:22 PM Reply With Quote
I personally know a guy at 'Galvanord'.
In germany (sorry)
They have a new micro zinc process.
Will only add 1 - 2% weight.
and wil last 35 years ^^
350€ it will set you back... :s incl etching your frame.
And you can get it in all RAL colours.
Some Morgan 3wheeler frames are been done, but BMW and Audi do all there
suspension this way... (the steel components)
posted on 22/12/13 at 02:49 PM Reply With Quote
The Hempathane works out at £10/L
5l of primer and 5l of top coat cost me £95, that included some rollers as well.
[Edited on 22/12/13 by coozer]
formerley IDONTBELIEVEIT
posted on 23/12/13 at 09:39 PM Reply With Quote
Hopley,
We powdercoat loads of chassis, from bare metal £150.00 any standard RAL colour plus many more non standard.
regards wayne
drt
posted on 24/12/13 at 02:01 PM Reply With Quote
Originally posted by formerley IDONTBELIEVEIT
Hopley,
regards wayne
150 isn't bad,
And how does it fair against corrosion ?
do you have some VDA/DIN 50018/Kesternich data?
I always fear the oxidation you can't see, like inside the tubes...
In the past I've tried to coat the inside via a small perforated tube (spray piant)
with a great variation in protection as a result...
Anyone any ideas ?
waggy
posted on 24/12/13 at 10:14 PM Reply With Quote
Anyone any ideas ?
I'm at a similar crossroads and I just wasn't sure what to do, I've decided I'm going to powder oat the outside of the chassis and I'm going to protect inside the tubes by filling with waxol and then tipping the chassis a few times to allow the excess to 'run out'. Just my 2c.
posted on 24/12/13 at 10:23 PM Reply With Quote
Waggy,
Remember to drill some good size holes at all the junctions prior to tacking and welding up
drt
posted on 26/12/13 at 01:51 AM Reply With Quote
so waxol?
Is it any good (like POR15 good?)
indeed leavid some holes will save you a massive headache later on
waggy
posted on 3/1/14 at 11:43 AM Reply With Quote
Waxol is great stuff, It really does work but it's dirty and messy.
New Topic New Reply
