Mx 5 advice
dbaz293672 - 11/8/18 at 07:36 AM
Hi I am currently fitting a mx5 1800nb engine and box into my mk, I am then using a ford diff so I have 2 questions really
1, is there an adapter plate to take the mc prop to ford diff
2, shortened sump, does anyone have one as I can and the engine to sit as low as possible
JonBowden - 11/8/18 at 03:28 PM
I believe that it is normally advised to have a propshaft made for your application.
I think the cost is normally £200 ish
ianhurley20 - 12/8/18 at 09:03 AM
I had an MX5 prop from my donor so sent it to (I think) Bailey Morris who cut it down, installed a sierra coupling and balanced it before returning, cost was £115. The important dimension for them is the distance from the very rear of the gearbox to the front face of the sierra diff flange, 650mm on mine if I remember correctly
dbaz293672 - 12/8/18 at 10:23 AM
Brilliant thanks for that I will make contact got to get the engine and box in first then will know where we are at
