Author: Subject: parts washer solvent is brilliant
FuryRebuild
posted on 21/3/12 at 09:29 AM Reply With Quote
So, I gave up on the surfactant based cleaner in the parts washer and put 25L of solvent based cleaner in from MachineMart.
Fantastic. The oil just melts away from the surface to be cleaned.
video here
I now smell of complex hydrocarbons
www.furyrebuild.co.uk
Chaddy
posted on 21/3/12 at 01:12 PM Reply With Quote
I use the same stuff, as you say it is fantastic
FuryRebuild
posted on 21/3/12 at 01:16 PM Reply With Quote
£80 for 25L is the painful bit. Looking for a cheaper supplier than MachineMart.
I'm going to put my block in there next and scrub it down.
I don't think there are any warnings about the wonderful fumes.
bartonp
posted on 21/3/12 at 03:35 PM Reply With Quote
Gunwash (cheap celly thinners) is a lot cheaper than that IIRC. Careful with it though!
Peter Perfect
posted on 22/4/12 at 04:16 PM Reply With Quote
I have just got a clarke parts washer and used the clarke parts washer fluied, which is not as good as the stuff in your video. what is the name of the solvent based cleaner you mention.
FuryRebuild
posted on 22/4/12 at 05:18 PM Reply With Quote
I used the machine Mart solvent. They sell both surfactant based cleaning fluid and evil chemical solvent.
It wasn't cheap at £80 for 30L or so but it did the job.
big_wasa
posted on 22/4/12 at 06:12 PM Reply With Quote
I use same sort of thing from my local hydraulics place and its made by witham oil.
