<<  2    3    4    5    6    7  >>
Author: Subject: 2.3L supercharged Locost
J666AYP
posted on 10/11/18 at 03:18 PM Reply With Quote
Abit of progress over the past couple of weeks.
• Have started covering the car loom in braid and routing the wires.
• Knocked up the cowling/cover for the steering column. Found a pipe conector in the local hardware shop, have turned town some alloy and ABS bungs so its a very tight fit with no screws needed. And it cost me a grand total of £0.89p. A lick off paint and it will be spot on.
• PAULD was kind enough to knock up a inlet manifold flange for me, I have cut my tubes up and started knocking up some injector seats on the lathe. Just need to get over to the welding shop to swap my gas bottle over then I can start throwing some sparks round the garage.
• The main power cables have been swapped for some lighter ones and fixed in place.
• Alarm is fitted and working.
• I have also thought up a great security device for the handbrake (well redneck engineering haha).
Jay
J666AYP
posted on 12/11/18 at 10:11 PM Reply With Quote
Got some nice little 45mm ID velocity stacks on route from china and started welding up the manifold. Has had two very heavy passes with the welder so it should never leak.
[Edited on 12/11/18 by J666AYP]
SJ
posted on 13/11/18 at 08:18 AM Reply With Quote
I love the handbrake lock!
posted on 13/11/18 at 05:17 PM Reply With Quote
Ditto - nice touch!
Angel Acevedo
posted on 13/11/18 at 06:02 PM Reply With Quote
Ditto - nice touch!
Even better, put a gaiter on top and talk about Stealth Security....
J666AYP
posted on 13/11/18 at 06:46 PM Reply With Quote
Cheers gents.
Angel.... Already on that Idea mate:
They should neaten up the holes in the gaitor.
Jay
J666AYP
posted on 15/11/18 at 05:46 PM Reply With Quote
Yep that works.
gremlin1234
posted on 15/11/18 at 06:38 PM Reply With Quote
whilst the hand brake lock looks good and functional
it would not pass iva as an immobiliser, because they are not allowed to work on any part of the braking system.
J666AYP
posted on 15/11/18 at 07:17 PM Reply With Quote
Gremlin1234,
It already has a alarm and immobiliser fitted, this is just a extra bit of security for when its parked up in some of the dodgey areas I visit.
Jay
gremlin1234
posted on 15/11/18 at 07:18 PM Reply With Quote
Originally posted by J666AYP
Gremlin1234,
Jay
good, but don't let it be seen at iva ;-)
J666AYP
posted on 15/11/18 at 07:25 PM Reply With Quote
Gremlin, those are "inspection holes" in the gaiter wink wink.
Jay
Iomlocosts4
posted on 17/11/18 at 04:47 PM Reply With Quote
Nice job! I can't wait to start myself!
posted on 17/11/18 at 09:46 PM Reply With Quote
You might want to think about either triangulating the front lower wishbones, or adding a curved plate to help distribute the bending stress. Particularly with a fairly heavy, powerful engine the design of yours is prone to failure due to the straight edge of the shock mounting plate turning a nice strong triangle into a weak trapezium shape.
J666AYP
posted on 17/11/18 at 10:24 PM Reply With Quote
MikeRJ,
I have welded this brace into both lower wishbones, will that not be enough? If not I will seam a plate into them.
Jay
J666AYP
posted on 21/11/18 at 06:24 AM Reply With Quote
Abit more progress on the inlet manifold Mk3.5 Just need the velocity stacks to land on the doorstep now :-/
Bluemoon
posted on 22/11/18 at 09:58 AM Reply With Quote
MikeRJ,
Jay
I think mike is talking in terms of vertical motion, lateral is fine for the lower bone as it makes a triangle with the mounts (i.e. the brace is not needed). On the locost the wishbone design fails where the plate meets the bones as this is a stress riser since the damper/spring load really wants to shock loads from the odd pothole ect cause the wishbones to fold up... MK and others have got around this by making the plate thin out into a U shape to remove the stress riser on the wishbone. Worth doing a search on "wishbone failure". Basically in an ideal world, the wishbone would only be under compression or tension but the shock absorber mount puts it under bending, in an ideal world the shock mounting would be at the same place as the pivot for the upright, clearly this is not physically possible. MK and Caterham have there own solutions to this...
Caterham moves the wishbone pivot as far out as possible:
MK us the U-shaped plate (note the plate is welded in the center of the tubes NOT the top):
Example of failure;
Dan
[Edited on 22/11/18 by Bluemoon]
J666AYP
posted on 22/11/18 at 04:34 PM Reply With Quote
Aaah that makes sence, silly me looking at the wide end of the wishbones haha.
Will get some bracing in the narrow end next time the wishbones are off.
Thanks for the input gents.
J666AYP
posted on 22/11/18 at 04:41 PM Reply With Quote
Todays been a good day! my velocity stacks turned up yay! bit of a bummer that they were too long to keep inside the factory sized body (its a mission of mine to keep it sleek and subtle). Had to turn them down in the lathe but they fit nice now.
Trial fitting...
J666AYP
posted on 23/11/18 at 03:33 PM Reply With Quote
Yep that works
Iomlocosts4
posted on 23/11/18 at 05:10 PM Reply With Quote
Looking good!
Yep that works
J666AYP
posted on 24/11/18 at 01:06 AM Reply With Quote
Cheers buddy,
Jay
J666AYP
posted on 24/11/18 at 01:19 AM Reply With Quote
Just been looking back through some old photos trying to find where a coolant hose goes to and I'm shocked at how far its come along. The time, effort and ear bashings from the wife are starting to pay off abit I think
J666AYP
posted on 26/11/18 at 12:10 AM Reply With Quote
Playing with the label maker and some clear heatshrink. Has worked quite well.
big_wasa
posted on 26/11/18 at 01:38 PM Reply With Quote
What label machine have you got ?
I've got two looms to build and that would add a nice touch.
J666AYP
posted on 26/11/18 at 03:29 PM Reply With Quote
Just a cheapy amazon one mate and some clear heatshrink tube from china. Let me know what you want and I will run some off for you if you want.
Jay
<<  2    3    4    5    6    7  >>
