Author: Subject: Trailer wanted
CTLeeds
posted on 15/11/18 at 08:52 PM Reply With Quote
Trailer wanted
Ideally looking for a twin axle flat bed as I don't have much width to play with in my garage. Min bed width 6ft, max overall width 6ft 8". Max overall length 16ft.
Thanks in advance.
Chris
Barksavon
posted on 16/11/18 at 06:27 PM Reply With Quote
I've got a single axle trailer which you may be interested in although overall width is 7 '4" and overall length ( tow hitch to end of bed) is 6'6" .
I've only used it once to take my Avon to a track day.....blew the engine up and not got round to putting my replacement ST170 in yet so it can go.
Let me know if you want more info
CTLeeds
posted on 16/11/18 at 06:39 PM Reply With Quote
It won't fit unfortunately. Thanks though.
Chris
jeffw
posted on 16/11/18 at 08:57 PM Reply With Quote
This might suit
http://www.uphillracers.com/showthread.php?t=16208
CTLeeds
posted on 16/11/18 at 09:06 PM Reply With Quote
I've contacted them, thanks for the heads up.
regards,
Chris
CTLeeds
posted on 16/11/18 at 09:50 PM Reply With Quote
Again, It's too wide. Still on the lookout...
Chris
Barksavon
posted on 17/11/18 at 08:08 AM Reply With Quote
Think you may struggle to get a 6' bed width with a max overall of 6'8" , that only gives 8" for wheels. ..unless you can find one with wheels positioned under the bed?
CTLeeds
posted on 17/11/18 at 08:54 AM Reply With Quote
Yep, that's exactly what I'm after.
posted on 17/11/18 at 05:09 PM Reply With Quote
I've been looking for a trailer that will fit in my lockup , the only one I've seen so far has removable wheels under the bed and a removable drawbar , unfortunately it has no brakes
jeffw
posted on 17/11/18 at 07:11 PM Reply With Quote
This is the only one I'm aware of which will fit the bill
http://www.allytrailer.co.uk/home/storage-applications
5' 11" wide, 160Kg unbraked which leaves you with 590Kg for the car on the trailer.
[Edited on 17/11/18 by jeffw]
CTLeeds
posted on 17/11/18 at 07:30 PM Reply With Quote
This is the sort of thing I'm after (just not in Devon!)
https://www.ebay.co.uk/itm/twin-axle-car-transporter-trailer-Had-Little-Use/323551442040?hash=item4b552b3478:g:5bEAAOSwi7Vb7X6X:rk:27:pf:0
