<<  1    2    3    4  >>
Author: Subject: Time for another build - Avon
Deckman001
posted on 2/3/20 at 04:34 PM Reply With Quote
Originally posted by Deckman001
Hi Sera,
Have you finished the throttle pedal connection to the carbs? I've got a very nearly identical set up but having never done anything like this before I'm not too sure whats the best connection method ?
Jason
Hi Jason, yes I used a generic Venhill kit off eBay, about 18 quid I think. Comes with all the fittings you need.
Sera
Sera, You have U2U
Jason
jacko
posted on 2/3/20 at 07:32 PM Reply With Quote
Originally posted by Memphis
Yes you'll have no trouble with the manifold under normal conditions on the road, but if (when) you come to tune the engine for serious power, it will be very restrictive.
[Edited on 2/3/20 by Memphis]
Hi Memphis
I'm interested for you to tell me why you think that manifold will not be good
the manifold is like that to miss the distributer
Graham
Memphis
posted on 4/3/20 at 09:43 AM Reply With Quote
Hi Memphis
Graham
Sharp turns in the manifold create large amounts of turbulence on both sides of the turn, thus restricting the cross sectional area of the inlet runner to a fraction of the original internal diameter. Airflow doesn't want to go around corners, and would far prefer to slam into the far side of the inlet runner. Ok on a mild road engine to a point (I suppose) but no good at all on a high performance application.Two sharp turns just compounds the problem.
I know a certain supplier of bike carbs manifolds sells hundreds of these things, but my heart sinks every time I see one! By far the best solution is to respace the carbs so you get as straight as possible shot down the inlet port. If you need to change direction, the curve must be as gentle as possible. Respacing is a faff and quite expensive, which is the main reason people don't do it; generally nothing to do with avoiding distributors, (and with semi downdraught modern carbs that isn't a problem anyway).
flak monkey
posted on 4/3/20 at 10:21 AM Reply With Quote
Quite right.... However have you actually looked inside the manifolds at how they are ported and finished off? There arent any 'sharp' corners inside at all. They are smoothed off nicely.
I agree a straight inlet runner would be preferable. I even have the tools and skills to re-space the carbs accordingly, but like I said... lazy...
Even re-spaced there would have to be a curve in the inlet manifold to position the carbs at the correct angle - would it be better? Yes, but still not perfect.
It all depends whether you are chasing the last few HP or not. I'm not, so chose to take this route. If it was a race car and I was going for maximum power I would have fitted throttle bodies to tuned length, straight inlet runners (actually matching the port angle in the head too) but I'm not. So this will do.
Sera
http://www.motosera.com
SJ
posted on 4/3/20 at 11:15 AM Reply With Quote
I agree it's a faff but for anyone with access to a lathe it's not expensive at all.
Memphis
posted on 4/3/20 at 12:27 PM Reply With Quote
Most people don't have access to a lathe, so they pay for it.
SJ
posted on 4/3/20 at 01:09 PM Reply With Quote
All you need is the fuel rail turned. Think mine cost about £30.
Rest is some threaded rod, ali tube and bits of steel to extend the throttle tabs. Costs buttons.
jacko
posted on 4/3/20 at 05:33 PM Reply With Quote
Sorry if I've opened a tin of worms but as has been said above most of these cars are road cars not race cars and a small bend is not going to make that much difference
I would like to say the engine I built was / is as far as I know as good as the day I built it
And as I was told years ago you need a bit of turbulence in a manifold to help mix the fuel and air
But of course I may be wrong as I often am lol
Graham
flak monkey
posted on 5/3/20 at 06:51 PM Reply With Quote
Drained the oil from the first run and refilled with fresh and a new filter, all looks OK at the minute. Using cheapo 20w50 mineral oil for bed in.
Stripped the carbs off (again) - it would intermittently run on 2 or 3 cylinders, after making certain it wasn't an ignition issue (it wasn't) it was time to pull the carbs. It was always likely to be fuel as cold starting was a nightmare.
Appeared the idle jets were at least partially blocked. Fired up spot on after refitting. Balanced the carbs and tweaked the idle mixture a little. Will see how it starts from cold again tomorrow.
Cooling system seems to cope OK, although it's not building pressure. I put it down to the cheap crappy header tank as there are no leaks. I've already put a genuine Ford cap on it, but it's still not pressurising. The fan and everything seems to work though, so I'll just get a genuine tank at some point.
Next job is clip the fuel hoses at the back, fit a different oil pressure send that doesn't need a load of adaptors, and tidy up a few cables. Then its going to have to wait until we can find some money for the bodywork. And I have a bike to get mSVA'd before that can happen!
Sera
jacko
posted on 5/3/20 at 07:28 PM Reply With Quote
Fantastic work and the pinto sound brings back memories
Graham
SJ
posted on 5/3/20 at 08:24 PM Reply With Quote
Are you using the choke? Makes a big difference on my zx6 carbs.
Stu
flak monkey
posted on 5/3/20 at 09:09 PM Reply With Quote
Stu
Yup. Wasnt working properly before. Nothing a strip down and compressed air couldn't fix it seems....
Sera
SJ
posted on 5/3/20 at 09:14 PM Reply With Quote
I've been amazed how well bike carbs work. Mine stands for months on end and fires up pretty much on the button.
Are you planning a rolling road setup session? I did mine at home but quite tempted to let Atspeed have a go.
flak monkey
posted on 6/3/20 at 09:14 AM Reply With Quote
I've got a WBO2 to fit - so will see how it goes....
Sera
Deckman001
posted on 6/3/20 at 08:36 PM Reply With Quote
The bike carbs on my old locost that I've got back and rebuilding since i sold it ten years ago, I drained down the petrol, flushed out the very yellow liquid it had turned into in the tank, pipes and carbs, refilled the tank with about 5 ltrs and they worked straight away when i got the new ignition system installed, so all in all I'm sure bike carbs seam fabulous, although my car now has a deep throated bang/pop from the exhaust occasionally while ticking over? it does make me smile though
Jason
flak monkey
posted on 6/3/20 at 08:40 PM Reply With Quote
Jason
Sounds like it's a bit lean.
Would probably benefit from a strip and clean if they have sat with old fuel in
Sera
Deckman001
posted on 7/3/20 at 11:44 AM Reply With Quote
Jason
Yeah sounds about right, I'll keep an eye on the plug colours and asses them before i book the IVA.
Thanks Sera, great advice as usual
Jason
Big T
posted on 16/3/20 at 05:45 PM Reply With Quote
Certainly not hanging about with this. Will keep an eye on your progress. Do you have a deadline you’re working to?
jps
posted on 16/9/21 at 10:50 AM Reply With Quote
Any update Sera?, I was enjoying watching your progress and just looked back on the thread to remind myself of the Polo rad/pinto piping arrangements…
flak monkey
posted on 16/9/21 at 11:17 AM Reply With Quote
I sold it as a part finished project a couple of months ago. I'd simply run out of bandwidth to do it and it's better that it went to another person to get it finished.
Sera
jps
posted on 16/9/21 at 12:30 PM Reply With Quote
A shame - was a good (and motivational) watch to see you roaring through it - but understandable, I know at times in the past my project has felt like a millstone round my neck!
<<  1    2    3    4  >>
