Trying to keep my rear end tidy and had a thought. As per the photo below, would I get away with welding brackets discretely on my bottom rail and
have my fog and reverse lamps mounted on these brackets with them connected with plug/socket arrangement so they could be removed when not
required?
Yeah be fine,just make sure the edges are OK on brackets,and fog light is vertical
Originally posted by CosKev3
Yeah be fine,just make sure the edges are OK on brackets,and fog light is vertical![]()
Originally posted by craigdiver
they could be removed when not required?
Also make sure that the Fog light has the correct markings on the Lens. Quiet a few after market Len's including the round land rover ones do not...
Reverse light is not required for MOT's. or SVA, not sure about the "new" IVA though.
eta, but if fitted, it must work of course.
[Edited on 1-6-18 by Slater]
Reversing light is part of the IVA.
