do i need dim/ dip head lights for the sva?
Hi Bass
No you don't.
Chris PTM
Hi Bass
No you don't.
Chris PTM
Hi all
Do you have to have sidelights?
Ben
yup
Could anybody enlighten me (no pun intended) as to the difference(s) between head-, driving-, and fog-lamps, and are they interchangeable? I want to fit a pair of rectangular headlamps, like on Daxs, but I can only seem to find ones that are sold as driving/fog lamps, i.e. the Cibie Airport ones, or Lucas Square 8s. Can anybody help?
You need headlights that will dip the beam downwards and to the left,and main that is designed to blind on comming drivers,citroen ami8 used similar headlights so could be worth a try not that i would condone using anything remotley french on your car
Driving lights tend to have a more directional beam, to see into the distance.
Fog lights disperse the light so as to illuminate in fog rather than creating a white streak in front of you .. .
