Speedo sensor help
pekwah1 - 28/11/17 at 08:50 PM
Hi Guys,
I have a digi dash which is not a brand anyone will have heard of, but my speedo pickup bracket failed and looks like i've killed the pickup as below:
It obviously just picks up off a magnet, but are these usually the same kind of sensor, i.e. can i just buy another one of a particular type and just chop and wire it into my existing connector?
Thanks in advance.
mcramsay - 28/11/17 at 09:06 PM
It depends if itís a Hall effect sensor or reed switch, how many wires are on the connector?
pekwah1 - 28/11/17 at 09:19 PM
2 wires sir
rusty nuts - 28/11/17 at 09:28 PM
Have a look at the Greengauges website, part of Speedy cables
mcramsay - 28/11/17 at 09:38 PM
http://www.acewell-meter.co.uk/Acewell%20Accessories%20and%20Sensors/Speed%20Sensors%20-%20Magnet%20type/ACE-G.htm?action=full&id=11
pekwah1 - 28/11/17 at 09:43 PM
thanks very much!
watsonpj - 29/11/17 at 08:07 PM
etb Digidash?
heres there sensor.
http://www.etbinstruments.com/index.php?route=product/product&path=99_110&product_id=56
Pete
MikeRJ - 29/11/17 at 11:34 PM
Originally posted by pekwah1
2 wires sir
Two wires suggest it may be a variable reluctance sensor (a coil of wire with a magnet) rather than hall effect. Have you tried measuring continuity across the wires with a multimeter? If it's open circuit then it's dead, otherwise they tend to have a resistance between a few hundred of ohms up to maybe 1 or 2 kohms.
