I have bought some carbs on a manifold , it was sold a zetec but its to narrow. The port spacing is 90mm for each carb and roughly 92mm between carbs. Also it has what looks like a water temp sensor in the middle of the manifold. Any thoughts on what car its off??
Any pics?
Sounds like pinto to me.
This is one of those cases where a pic would really help
[Edited on 20/4/09 by mookaloid]
Pinto
CVH Escort type
Could even be a crossflow. You really do need to provide more info (and remember a picture is worth 10,000 words
John
Originally posted by Thinking about it
CVH Escort type
if you need a zetec manifold I may be able to help out u2u me if needed
Also going for CVH 1.6 Litre engine, water course between 2nd and 3rd cylinder.
Adrian
smaller capacity (than expected) zetec?
ie, its for a 1.4 where you wanted a 2.0?
if they do a 1.4 zetec?
bear in mind i've never seen a zetec I'm just getting involved in the guessing game
your right about the piccy but its at my dads with the carbs on, will try to get one. Thanks for the gusses though!
