New Topic New Reply
Author: Subject: Why, oh why?
C10CoryM
posted on 26/7/07 at 02:44 AM Reply With Quote
Why, oh why?
Do you guys always stick the battery so high up in the car?
I am partially joking, but also wondering why on such a light car you put what is probaby the 6th heaviest component so high up. It looks like there is usually room lower in front of the passenger footbox.
Maybe left over from the days of old lucas wiring so you can disconnect the battery in a hurry?
Cheers.
"Our watchword evermore shall be: The Maple Leaf Forever!"
James
posted on 26/7/07 at 02:51 AM Reply With Quote
Mine's in the passenger footwell!
And I'm planning to move it out as it's a pain in the arse losing the storage space!
designer
posted on 26/7/07 at 06:19 AM Reply With Quote
The basic principle of the battery is that it should be mounted as near to the starter motor as possible due to the voltage drop in the wire.
Avoneer
posted on 26/7/07 at 06:23 AM Reply With Quote
Mines' on the floor behind the steering rack.
Pat...
worX
posted on 26/7/07 at 06:56 AM Reply With Quote
my battery is mounted in front of the passenger footwell, and still utilises the leads from the bike...
Agriv8
posted on 26/7/07 at 07:04 AM Reply With Quote
Mine in the passenger footwell !.
Under the scuttle ( so cant see that the wireing is that much longer than having it sat on the scuttle )
Oh it also helps to keep the battery cool !
regards
Agriv8
mark chandler
posted on 26/7/07 at 08:11 AM Reply With Quote
Mines right by the engine also, but I dragged everything I could inside the wheel base of the car so the Rad moved back also.
Advantage of both weight, standard battery leads from bike and regulator sits by battery so gets lots of passing air. Rescued attachment battery.JPG
posted on 26/7/07 at 08:31 AM Reply With Quote
Mine's on above the passenger footwell in the engine bay. The battery to starter lead is now thicker and shorter than in the donor car.
I'd like to have put it in front of the footwell in the engine bay, but with a car engine and battery there wasn't enough room.
I did also consider taking some space inside the passenger footwell, but that would make it very awkward for passengers and reduce the already minimal stowage space too.
russbost
posted on 26/7/07 at 08:45 AM Reply With Quote
"The basic principle of the battery is that it should be mounted as near to the starter motor as possible due to the voltage drop in the wire."
Well, yes when we had inertia starters & points ignition. Nowadays there is no reason not to put the battery in the most advantageous place - surely for 7 clones that would be behind the rear axle, get some weight over those driving wheels!
nitram38
posted on 26/7/07 at 09:27 AM Reply With Quote
There is not much volt drop in battery cable if you use the right size!
If you move a battery further away, just get a slightly bigger cable.
iank
posted on 26/7/07 at 09:48 AM Reply With Quote
Mini worked perfectly well with the battery in the boot.
As nitram38 says if you get the correct size cable you can put it in the best place for weight distribution.
Anonymous
lsdweb
posted on 26/7/07 at 11:49 AM Reply With Quote
I'd suggest go on:
A - Safest position
B - Best for weight distribution
C - Shortest cable runs (alhtough not a huge problem)
Mine's under my knees btw.
Wyn
Hellfire
posted on 26/7/07 at 04:15 PM Reply With Quote
Centrally mounted behind steering rack level with bottom of chassis.
RoadkillUK
posted on 26/7/07 at 05:42 PM Reply With Quote
Does it really matter? Just make sure you've got one that works
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
New Topic New Reply
