New Topic New Reply
Author: Subject: Engineer's input required, rocker suspension
mr henderson
posted on 3/12/09 at 11:57 AM Reply With Quote
I've attached a sketch of the way I think the forces involved in a rocker suspension work on the chassis. The assumptions are that the sprung weight of the corner is 150kg, and that the pivot on the rocker (point X) is in the middle.
Have I got this right?
tegwin
posted on 3/12/09 at 12:11 PM Reply With Quote
What about the lateral (left/right) forces? That top pivot will be hit with a lot of lateral force!
www.verticalhorizonsmedia.tv
MikeCapon
posted on 3/12/09 at 12:13 PM Reply With Quote
Hi Mr H. My view in my flued up state is the following.
Point Y. As it's a 1:1 ratio 150kgs in equal 150 kgs out so agreed.
Point X. Disagree here. Effectively the cars weight is all sitting on this pivot so it's 150 kg for me.
ETA. Doh.. Of course the rocker is effectively a 2:1 lever thus doubling the force to 300 kg. Matt, you were right and I was wrong.
Mike
[Edited on 3/12/09 by MikeCapon]
matt_gsxr
posted on 3/12/09 at 12:14 PM Reply With Quote
I'm no chassis engineer, just a physicist but.
If the rocker is equal length then...
The chassis is pushing up at Y with 150kg force (yuck I know I should use N). In the same way that the rocker at the other end is being pushed up by the wheel.
Therefore the rocker at X is being pulled away from the chassis with a 300kg (3000N force).
I hope that makes some sense. You can think of it by thinking what would happen if you took out a bolt (where would it go).
Matt
Dangle_kt
posted on 3/12/09 at 12:21 PM Reply With Quote
Matt
what, into an old roses tin along with about 50 other bolts I can't find when I need them?
liam.mccaffrey
posted on 3/12/09 at 12:43 PM Reply With Quote
Assuming the corner weight is 150kg taking moments about the inner upper connection tells you with a 1:1 ratio the middle pivot must be twice the 150kg.
Matt is right
[Edited on 3/12/09 by liam.mccaffrey]
Build Blog
Build Photo Album
Liam
posted on 3/12/09 at 12:45 PM Reply With Quote
I had to work all this out for my design and if I recall (a long time ago!) matt-gsxr is correct. The pivot sees the corner weight plus the reaction from the spring, i.e. corner weight x rocker ratio (only 1 in your 1:1 example) trying to pull it off the chassis. In other words a rocker pivot has a hard life! Even more so if you have something more than a 1:1 ratio on the rocker as I do - i.e. shorter length inboard.
Liam
hughpinder
posted on 3/12/09 at 12:50 PM Reply With Quote
I'm with matt_gsxr on this one.
Hugh
rachaeljf
posted on 3/12/09 at 12:59 PM Reply With Quote
What he said
The fulcrum reaction equals the sum of the two end reactions. 150 + 150 = 300 I believe.
Cheers R
mr henderson
posted on 3/12/09 at 01:16 PM Reply With Quote
Thanks for that chaps, makes very good sense.
aitch
posted on 3/12/09 at 01:54 PM Reply With Quote
and of course these are only static loads
if the inboard section is shorter then the loads are higher (wouldnt it??)
e.g if the inboard section is half the length the leverage is halved, therefore the spring and dampner assembly would be under a 300kg static load and the pivot 450kg static load.. ??
this seems right in my head
aitch
posted on 3/12/09 at 05:45 PM Reply With Quote
Also be aware of the very high bending moment exerted by the lower end of the spring-damper unit on lower member.
[Edited on 3/12/09 by britishtrident]
Benonymous
posted on 8/12/09 at 11:44 PM Reply With Quote
This probably explains why most inboard shock absorbers are connected to the suspension via a pushrod and a bellcrank. In Staniforths book I noticed the rocker/wishbone set ups would create these very significant loads and have the disadvantage of being difficult to alter or adjust in some ways.
posted on 9/12/09 at 01:43 AM Reply With Quote
The loading on bellcrank and pivots can be very high as well.
aitch
posted on 9/12/09 at 07:56 AM Reply With Quote
and more connections linkages and pivots in a bell crank design, but it is more adjustable by its nature and more options to position of the spring dampner assembly
aitch
[Edited on 9/12/09 by aitch]
kb58
posted on 9/12/09 at 02:42 PM Reply With Quote
There's something wrong with this picture; since the car isn't moving, the total forces must total to zero.
There's 150kg pushing the outer end of the rocker upward, and since the rocker's balanced (not rotating), it means there's also 150kg upward force acting on the inboard end. Therefore, there's 150kg downward force on the bottom of the spring, so there's 150kg net upward force on the rocker-arm pivot, not 75kg.
[Edited on 12/9/09 by kb58]
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
mr henderson
posted on 9/12/09 at 04:02 PM Reply With Quote
The others seem to think that it's 300kg at that point, and I would have to say their explanation sounds good to me. Could you elaborate as to why you believe that it is 150kg?
kb58
posted on 9/12/09 at 04:28 PM Reply With Quote
I think the problem, maybe with my own opinion, is what the frame of reference is. I'm trying to look at just the frame - no tire - in order to remove the confusion of an external reference.
I'll revisit this later when I have more time... maybe I need to pull out my statics book...
Liam
posted on 9/12/09 at 05:13 PM Reply With Quote
In a nutshell, you can consider that the 300kg pushing the rocker pivot upwards, is resisted by the 150kg spring force plus the 150kg corner weight pusing downwards.
Badger_McLetcher
posted on 9/12/09 at 06:23 PM Reply With Quote
The way I see it:
If disfunction is a function, then I must be some kind of genius.
aitch
posted on 9/12/09 at 06:31 PM Reply With Quote
Originally posted by Badger_McLetcher
The way I see it:
cant argue with that
way i see it if the load is 150kg acting upwards on the arm then the oposing force of shock with the same leverage has to be the same 150kg acting upwards on the arm,providing a total 300kg upward force that requires a 300kg downward force on the pivot point...
aitch
boggle
posted on 9/12/09 at 09:57 PM Reply With Quote
wow....this is just like being back at college doing my H.N.D.
have you considered a single large damper mounted horizontal?
[Edited on 9/12/09 by boggle]
u2u me for details
New Topic New Reply
