New Topic New Reply
Author: Subject: Cleaning a Pipercross foam filter
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
Building: Flexibility into my marriage, bless her!
posted on 20/10/10 at 04:19 PM Reply With Quote
Unfortunately my filter is green and currently filthy.
Two little questions:
1) Can I just dunk it in petrol or is that fancy spray on cleaner needed?
2) How do you re-oil it afterwards?
RazMan
posted on 20/10/10 at 04:22 PM Reply With Quote
Standard engine cleaner and a jetwash works well for me.
Raz
jossey
posted on 20/10/10 at 04:27 PM Reply With Quote
water
dave
cliftyhanger
posted on 20/10/10 at 04:30 PM Reply With Quote
CRIKEY, tought that would have mullered a foam filter!
I have used hot water an bio washing powder. Leave in soak, rinse and job done. Do foams need oiling? thought it was just the cotton type.
PAUL FISHER
posted on 20/10/10 at 04:38 PM Reply With Quote
I cleaned mine in petrol, then hot water with a little bit of washing up liquid, then rinsed it out and dried it, its the filter oil you can't realy get away without using the correct stuff, as its sticky stuff that bonds to the filter, and will not get stucked through into the inlet manifold, which could cause problems if oil gets onto the map sensor etc, the oil is only about £5, I bought mine off ebay.
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
posted on 20/10/10 at 04:41 PM Reply With Quote
Right!
Thanks gents, off to fill the bath and fire up Ebay.
Ed
Bluemoon
posted on 20/10/10 at 06:19 PM Reply With Quote
^^^ Foam types normaly need oiling, (check with the manufacture, but ones that don't are probably rather rubbish at filtering) else they don't filter.
[Edited on 20/10/10 by Bluemoon]
snapper
posted on 20/10/10 at 06:52 PM Reply With Quote
Wash it from the inside outwards, that drives the dirt particles out the way they came in.
Yes the proper filter oil is essential to make the filter work properly
I eat to survive
I drink to forget
New Topic New Reply
