New Topic New Reply
Author: Subject: s2k locost
dimlaz
posted on 12/2/12 at 05:53 PM Reply With Quote
s2k locost
Hello
I'm from Greece and i have the ambition to build a locost with engine from honda s2000. Because this engine is bigger than usual I desided to use the mcsorley plans (+442) instead the book plans. I had began the chassis construction the last summer and now i'm building the front wishbones.
Here some photos from my progress
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[Edited on 12/2/12 by dimlaz]
l0rd
posted on 12/2/12 at 07:25 PM Reply With Quote
Looks good.
Where about in Thessaloniki are you?
dimlaz
posted on 12/2/12 at 07:37 PM Reply With Quote
I'm in Evosmos.
dimlaz
posted on 12/2/12 at 07:41 PM Reply With Quote
More pictures
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
l0rd
posted on 12/2/12 at 07:48 PM Reply With Quote
I am not building at the moment but should drink a cup of coffee sometime
I am in Kalamaria
[Edited on 12/2/12 by l0rd]
dimlaz
posted on 12/2/12 at 07:50 PM Reply With Quote
I would like too!
dimlaz
posted on 12/2/12 at 07:55 PM Reply With Quote
Engine pictures...
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
and the damaged engine
[img][/img]
dimlaz
posted on 27/5/12 at 10:13 AM Reply With Quote
front lower wishbones allmost ready.
photos in my archive.
[Edited on 27/5/12 by dimlaz]
dimlaz
posted on 27/10/12 at 10:40 AM Reply With Quote
recently progress....
posted on 28/10/12 at 10:05 AM Reply With Quote
Cut the middle out of the rail across the chassis and put your gear lever where you can reach it from the driver seat then make your tunnel fit round it. Remember to leave room for your feet and pedals though.
dimlaz
posted on 28/10/12 at 08:19 PM Reply With Quote
thanks for your advice.
the possible engine position will be about 2'' back.
i think i follow your advice and i put the seat on place to find out the final position.
dimlaz
posted on 6/1/13 at 03:45 PM Reply With Quote
Xmas progress...
dimlaz
posted on 19/5/13 at 05:53 AM Reply With Quote
progress......
Slimy38
posted on 19/5/13 at 07:32 AM Reply With Quote
May I ask a couple of questions? The diff fixing looks a little weak although it does look like standard mounts, is there something a bit bigger on the front or underneath the diff also fixing it to the frame? I can't really tell from the pictures. I'm just comparing them to the normal Sierra diff mount which is a steel plate fixing with reinforcement.
The lower rear wishbones also look like they've got no triangulation in them, aren't they just going to twist and snap as soon as you accelerate?
dimlaz
posted on 19/5/13 at 09:13 PM Reply With Quote
i have 2 mounts on the front like engine mounts.
the rear wishbones is adjustable and i m going to weld the triangulation pipe only if is necesery (after the test run).
Fred W B
posted on 20/5/13 at 07:32 PM Reply With Quote
You absolutely do need the diagional in the lower rear wishbones.
Fred W B
dimlaz
posted on 12/1/14 at 08:34 PM Reply With Quote
finally on wheels!
daveb666
posted on 14/1/14 at 12:49 PM Reply With Quote
why's the drivers side wheel all bent back?
matt_gsxr
posted on 14/1/14 at 01:02 PM Reply With Quote
because there are no front shocks/springs yet and its on a bump.
dimlaz
posted on 14/1/14 at 04:19 PM Reply With Quote
Yes it's because there are no front shocks/springs yet and its on a bump. I think after the shocks placement it will be ok.
dimlaz
posted on 17/7/16 at 10:18 PM Reply With Quote
Progress at last....
[Edited on 17/7/16 by dimlaz]
dimlaz
posted on 17/7/16 at 10:24 PM Reply With Quote
dimlaz
posted on 17/7/16 at 10:32 PM Reply With Quote
And the first start video
[youtube]https://youtu.be/r2QDa6Gci1U[/youtube]
jeffw
posted on 18/7/16 at 07:47 AM Reply With Quote
dimlaz
posted on 12/11/17 at 05:45 AM Reply With Quote
[Edited on 12/11/17 by dimlaz]
New Topic New Reply
