New Topic New Reply
Author: Subject: Jacking Points
JamesyCottony
posted on 8/3/15 at 08:40 AM Reply With Quote
Jacking Points
Right, Where is the best place to jack the bobcat? corner of chassis? I know that the suspension arms are a no go so where would you guys say?
pewe
posted on 8/3/15 at 10:28 AM Reply With Quote
Side just below the dashboard looks good - plenty of strength there I reckon.
Alternatively in-board near the engine mounts.
With our type of car you're not talking a huge amount of weight so think where the heavy bits are and jack accordingly.
HTH.
Cheers, Pewe10
JamesyCottony
posted on 8/3/15 at 11:01 AM Reply With Quote
Thanks for that, what about at the rear? Corner of chassis?
pewe
posted on 8/3/15 at 12:08 PM Reply With Quote
Should be OK, my rule of thumb is to look for parts of the chassis which also have a vertical because that's inherently stronger.
Cheers, Pewe10
Angel Acevedo
posted on 9/3/15 at 04:44 AM Reply With Quote
Suspension arma are not necessarily bad If you jack near the pivots or near the shock mount.
Provisions may be needed to avoid slippage or scraping paint or finish though
Jacking near the shock mount provides the greatest lift with Te least amount of jack travel as you are effectively lifting the wheel
HTH
New Topic New Reply
