Author: Subject: Alloy front hubs
Shooter63
posted on 18/3/17 at 08:10 AM Reply With Quote
Alloy front hubs
My kit runs cut down mk2 escort front struts as uprights, I'm looking to change the hubs to alloy, does anybody know if such a thing Exists?
The struts are normal mk2 escort not the rs type with the seperate steering arms, all the hubs I can find seem to be only for rs type.
Shooter
ian locostzx9rc2
posted on 18/3/17 at 08:21 AM Reply With Quote
Rally design do them or they used too or try a rwd ford specialist.
obfripper
posted on 18/3/17 at 10:30 AM Reply With Quote
IIRC the rally design ones were mk5 cortina dimensions and so were burton ones, which have different spacing between the bearings and a different disc offset.
Hispec do them, but IIRC also have their own disc offset, they might do a set with standard dimensions if you ask and can wait... i'm still waiting for a reply.
I've seen these; i have no idea how good they are but they described as a direct replacement, they didn't do them a couple years ago when i was looking for alloy hubs. The only thing i can see is the centre spigot is tapered, so the wheel will be boltcentric location only - assuming the pic is of the actual item.
http://www.godspeedmotorsport.co.uk/front-suspension/538-ford-mk1-mk2-escort-alloy-hubs-to-suit-1100-1300-1600-sport-harrier-struts.html
Dave
Shooter63
posted on 18/3/17 at 10:09 PM Reply With Quote
The godspeed ones look good, I'll give them a bell
Shooter
loggyboy
posted on 18/3/17 at 10:21 PM Reply With Quote
Mk1 Mk2 Escort Rs2000 Mexico Rs1800 Capri Bilstein Alloy Hub Package
Shooter63
posted on 18/3/17 at 11:00 PM Reply With Quote
Wrong type for my struts, they are for the rs models.
Shooter
